Having a little trouble with my Steel City Mortiser!
Forum topic by Beginningwoodworker posted 04-09-2011 02:31 AM 1079 views 0 times favorited 13 replies Add to Favorites Watch
Beginningwoodworker
13345 posts in 3698 days
04-09-2011 02:31 AM
I haveing trouble with my Steel City benchtop mortiser boging down and chisel bit smoking, I been using a 3/4’’ mortise chisel to cut 3/4’’ mortises in Red Oak. I sharpen the chisel but I am still having the same problem. I also have to bear down hard on the handle.
13 replies so far
13606 posts in 3366 days
#1 posted 04-09-2011 02:51 AM
do you have enough clearance between the bit cutter
and the chisel
i was taught to slide the chisel up and use a nickle
between it and the machine body
temporarily tighten
slide the drill up to the chisel and tighten
then loosen the chisel
and take out the nickle
and slide it up and tighten
and go slow with the harder woods
View ChuckV's profile
ChuckV
3124 posts in 3552 days
#2 posted 04-09-2011 03:02 AM
There are some good tips here.
I notice that David’s nickel has been replaced by a dime – I guess that’s inflation!
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View NBeener's profile
NBeener
4816 posts in 3199 days
#3 posted 04-09-2011 03:04 AM
More info:
http://lumberjocks.com/topics/16460
Also …. you can use beeswax on the drill bit. It can make a BIG difference.
Free tools, huh ? LOL !!
-- -- Neil
View jack1's profile
jack1
2107 posts in 4052 days
#4 posted 04-09-2011 03:31 AM
Maybe a bigger hammer?? ;0) JK (just kidding…)
Seriously, go slowwwwww with oak.
Beginningwoodworker
#5 posted 04-09-2011 04:18 AM
I try to set it up with a dime.
jack1
#6 posted 04-09-2011 04:22 AM
Hammer the dime in with a bigger hammer… ;0)
35125 posts in 4425 days
#7 posted 04-09-2011 06:46 AM
I’d use the nickle. You do need clearance.
#8 posted 04-09-2011 06:49 AM
x
Beginningwoodworker
#9 posted 04-09-2011 06:55 AM
So the nickel would be better?
View degoose's profile
degoose
7234 posts in 3380 days
#10 posted 04-09-2011 10:40 AM
All the above advise seems to be reasonable to me…
View Greedo's profile
Greedo
473 posts in 2985 days
#11 posted 04-09-2011 01:05 PM
on my jet mortiser there are spacers provided that you use to tighten the drill, then remove them, push the chisel up and tighten.
there are two spacers, for larger chisels you must use both. each are about 3mm thick. so for your 12mm chisel i think my Jet manual prescribes 6mm difference. about 1/4th inch
View Tim Dahn's profile
Tim Dahn
1567 posts in 3590 days
#12 posted 04-09-2011 01:13 PM
Hey Charles, I just checked my Steel City manual, it states 1/16” to 3/16” clearance between the auger and chisel. My opinion is the bigger the bit the bigger the gap.
#13 posted 04-09-2011 01:44 PM
and the side of the auger too
it shears off the curls
from the chisel points
as they come into the bit
to far back
and the curls just clog things up
