Walker Turner lathe restore question.
« back to Woodturning forum
Forum topic by JPalumbo posted 02-12-2018 02:39 PM 575 views 0 times favorited 3 replies Add to Favorites Watch
View JPalumbo's profile
JPalumbo
2 posts in 521 days
02-12-2018 02:39 PM
Hi ya’ll,
I have a question for you Walker Turner Lathe owners. I am in the middle of a tear-down and restore of a WT L953. It is a four speed and sits atop a WT base. There is supposed to be a wood shelf between the base and the bed. However, when I got this unit the bed was sitting directly on the base. I want to replace this maple shelf but can’t find dimensions for it. Can someone share the dimensions with me?
Thanks so much!
Jon
3 replies so far
View Woodknack's profile
Woodknack
12430 posts in 2578 days
#1 posted 02-12-2018 11:11 PM
You have the lathe and base, can’t you measure it. Or check the manual?
http://vintagemachinery.org/pubs/808/1517.pdf
View John Smith's profile
John Smith
1481 posts in 360 days
#2 posted 02-12-2018 11:24 PM
there was a similar post a few years back: http://lumberjocks.com/topics/62347
google turns up a lot of info: it is within the 1930s – 1940s vintage.
-- I started out with nothing in life ~ and still have most of it left.
JPalumbo
2 posts in 521 days
#3 posted 02-13-2018 06:05 AM
Thanks for the replies. Actually I have a 1952 WT L953. Unfortunately, When you google 953 there is not much information at all. There is, however, plenty on the 951, 952, 1152. The dimensions of the bed are different but with that Product Spec sheet from the 951 I can figure from there. On mine, as with the 5110, the motor is slung beneath the bed and not out the back like a 951. This meant I needed to know if the board was 4/4 or 3/4 or whatever so the motor mount studs would fit properly. I’m just trying to do this restore as historically accurate as possible.
Thanks for all ya’lls help!
Jon
