Resharpening Table Saw Blades
Forum topic by Don Broussard posted 02-11-2018 10:14 PM 515 views 0 times favorited 6 replies Add to Favorites Watch
View Don Broussard's profile
Don Broussard
3647 posts in 2367 days
02-11-2018 10:14 PM
Topic tags/keywords: sharpening question
I have several older carbide-tipped blades that I can resharpen and return to service. I was curious if it is practical to reshape the teeth profiles from ATB to FTG, or if the idea is dead in the water. I would appreciate comments on whether there are safety issues I should be concerned about as well as general comments. I don’t want to end up in a future episode of America’s Dumbest Ideas. BTW, I do have a Foley Belsaw Auto Sharp and grinding wheels for sharpening circular blades.
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
View knotscott's profile
knotscott
8120 posts in 3491 days
#1 posted 02-11-2018 10:27 PM
Carbide tipped doesn’t ensure quality. If it was a quality blade to startwith and there’s sufficient carbide left, it should be feasible if a flat top grind will suit your needs.
Whether or not to do it yourself is a separate question. It doesn’t cost much to gain access to some very expensive equipment and the expertise to run it. My view has always been that I wouldn’t touch my expensive blades myself, and the cheaper blades aren’t worth the effort…on the other hand, if you have the machine you could always experiment.
Don Broussard
#2 posted 02-11-2018 10:50 PM
Thanks, knottscott. I agree with you about expensive blades but I have some old blades that I’m not using and need resharpening anyway. I probably will try an ATB – FTG conversion as an experiment. I just wanted to make sure that it wasn’t a just plain dumb idea.
View Woodknack's profile
Woodknack
12329 posts in 2495 days
#3 posted 02-12-2018 12:55 AM
If you have a local blade sharpener, maybe ask if they will do it. If they say no, then it’s probably a bad idea.
Don Broussard
#4 posted 02-12-2018 12:56 AM
Good thought, Rick. I don’t think we have a local sharpener but I’ll ask around.
View MrRon's profile
MrRon
4986 posts in 3359 days
#5 posted 02-12-2018 10:53 PM
Changing from ATB to FTG removes a lot of carbide. I don’t think you can use the Foley, auto sharp (sharp all?). Isn’t that for non-carbide blades only? You need diamond to sharpen carbide. I have a Foley model 310 carbide grinder that is designed for that purpose.
Don Broussard
#6 posted 02-13-2018 12:56 AM
Good point, Ron. I did get a bunch of grinding wheels when I got my SharpAll and I haven’t really inventoried to see if I might have a diamond wheel in my box of goodies. Thanks for the comment.
Plan change: If I don’t have a diamond wheel, I’ll take a non-carbide ATB blade to practice a FTG conversion.
