Determining cause of runout in old Craftsman drill press
Forum topic by Hennessy posted 04-08-2011 08:30 AM 1499 views 0 times favorited 1 reply Add to Favorites Watch
View Hennessy's profile
Hennessy
5 posts in 2846 days
04-08-2011 08:30 AM
I have a 74 Craftsman drill press (113.21371) that has considerable runout. I took the chuck off and when I spin the spindle in the quill I can see the chuck end of the spindle wobbling.
I’m pretty sure that the spindle is bent and its not something else causing the runout but I’d like to make sure before I order a new spindle. Any advice?
1 reply so far
View MarcusM's profile
MarcusM
57 posts in 3220 days
#1 posted 04-08-2011 02:56 PM
Hennessy, I don’t know that particular press but if it has a morse taper spindle I’d remove it, clean it up well, and reseat it. Sometimes a little corrosion or other residue on/in the taper will cause runout. Just don’t use a lubricant to clean it or, if you do, clean it off very well with something like alcohol.
Good luck, Mark.
-- Tilbilly Mark
