Sawdust solution.
Forum topic by Edziu posted 04-08-2011 02:22 AM 3759 views 2 times favorited 7 replies Add to Favorites Watch
View Edziu's profile
Edziu
151 posts in 3051 days
04-08-2011 02:22 AM
Topic tags/keywords: sawdust saw dust dispose disposing burn burning woodstove stove heat fuel
I often see lots of topics in the forums here on what to do with sawdust. I still use it in my garden as mulch, but I also recently discovered an efficient way to burn the stuff in my wood stove. I start by collecting small boxes that, when closed, will fit in my stove. I scoop some sawdust into the box, and tamp it down, repeating this several times.
Then I stomp on the sawdust to really get it compacted.
I add a little more sawdust and make sure there’s a little extra before I close the box, then I force the flaps down and tape the box shut.
I end up having a very dense pack of sawdust, almost as dense as a block of wood that is the same size. Then I throw it in the fire- and this is very important- On top of hot coals. Just lighting the box alone will work, but not well. when you put it on top of hot coals, it really burns nicely- for an hour or so.
I can process a whole 55-gallon drum of sawdust into about 8 or 9 boxes of this stuff in about an hour. I feel that’s a pretty good return on the investment of time.
7 replies so far
View wseand's profile
wseand
2796 posts in 3042 days
#1 posted 04-08-2011 04:21 AM
I will send you mine, expect a large box from FedEX… ;~)
View bubinga's profile
bubinga
861 posts in 2668 days
#2 posted 04-08-2011 05:00 AM
Do you get flames for an hour ?
-- E J ------- Always Keep a Firm Grip on Your Tool
Edziu
#3 posted 04-08-2011 06:11 AM
I do get flames for an hour, they’re not roaring, but similar to those of a duraflame log.
bubinga
#4 posted 04-08-2011 07:08 AM
I was thinking of that exact same thing,but didn’t try it yet, you put nothing but saw dust in the box ,right ?
No binder ?
TopamaxSurvivor
18272 posts in 3676 days
#5 posted 04-08-2011 07:15 AM
I have burned some that way too, but I don’t create enough :-) Box or 2 a year. Paper rolled up tight will burn about the same, but not quite a good.
View Gene Howe's profile
Gene Howe
10479 posts in 3429 days
#6 posted 04-08-2011 02:32 PM
Great idea.
When I saw your first 3 pictures, I was reminded of a story about disposing of garbage during a garbage strike in NYC I believe.
The home owner boxed it up nicely and left it in his/her unlocked car. Within a few hours, it was stolen.
View Dan's profile
Dan
3630 posts in 2881 days
#7 posted 04-08-2011 03:25 PM
I don’t burn my sawdust but I do a lot of planing by hand and get huge piles of plane shavings. I use the plane shavings to start the fires in my woodstove. They work a lot better then the starter logs or newspaper. Maybe I will try your box idea next winter.
-- Dan - "Collector of Hand Planes"
