Shop Vac "auto-on" Question
Forum topic by pete79 posted 04-07-2011 07:26 PM 1976 views 0 times favorited 4 replies Add to Favorites Watch
View pete79's profile
pete79
154 posts in 3138 days
04-07-2011 07:26 PM
I like the idea of getting one of those outlets that will automatically turn on your dust collection/shop vac when you turn on a certain tool. I happen to run my tools on a different outlet AND line from what my shop vac runs on. I’m curious if anyone knows how you would set up an auto on/off for the vac in that situation? I don’t know much of anything about this, so maybe it’s really simple?
-- Life is a one lap race.
27250 posts in 3819 days
#1 posted 04-07-2011 08:01 PM
Pete, I don’t know if it would work for you or not but when I run my tools (sander, router, etc) and shop vac hooked into a power strip with an on/off switch. I use the switch on the power strip to control the on/off operations of the tool and shop vac.
16274 posts in 4215 days
#2 posted 04-07-2011 08:03 PM
Pete, you might want to check out this discussion:
http://lumberjocks.com/richgreer/blog/14423
TopamaxSurvivor
18269 posts in 3673 days
#3 posted 04-07-2011 08:47 PM
You can PM me is that doesn’t answer your questions.
View crank49's profile
crank49
4030 posts in 2968 days
#4 posted 04-07-2011 10:18 PM
http://www.woodcraft.com/Product/2080165/28298/iVac-Automated-Vacuum-Switch.aspx
This link is for a power switch with two input lines. This is a common requirement for when the combined load of two devices exceed the capacity of a single circuit.
There are, most likely, many other sources for this device, but I happened to be looking at it in Woodcraft the other day so I knew they had it.
