Sacrificial insert saves sled's integrity
Forum topic by bubinga posted 04-07-2011 07:20 PM 3528 views 1 time favorited 2 replies Add to Favorites Watch
View bubinga's profile
bubinga
861 posts in 2569 days
04-07-2011 07:20 PM
Topic tags/keywords: tip jig trick tablesaw sled milling
2 replies so far
View Bertha's profile
Bertha
13495 posts in 2595 days
#1 posted 04-07-2011 07:23 PM
Very clever. I wish I had incorporated this into my crude tenon jig that I use on a $99 tablesaw. It’s getting pretty gnarly in the back & I don’t want to build another. Out of laziness, I bought the Rockler one. It’s solid but one HEAVY jig.
View sh2005's profile
sh2005
97 posts in 3138 days
#2 posted 04-07-2011 09:29 PM
On my latest (2nd one) crosscut sled, I had tried to incorporate a removable insert for the fence. My reasoning was that if/when the fence gets out of alignment, it will mean that the fence will no longer be a “zero clearance” fence. While building it, I found out that the effort to have the insert aligned, flushed and rigidly mounted wasn’t as easy as I had imagined. A better alternative is to mount a second fence on the face of the first fence, if the cutout on the original fence becomes too wide.
The idea of the sacrificial insert is good, because that way you can use multiple different blades and will always have the zero clearance with every single blade.
