Rout-r-lift II question
Forum topic by BenDupre posted 02-10-2018 04:34 PM 890 views 1 time favorited 7 replies Add to Favorites Watch
View BenDupre's profile
BenDupre
681 posts in 660 days
02-10-2018 04:34 PM
Topic tags/keywords: jessem router lift
Just ordered the jessem rout-r-lift II from woodcraft because its on sale this month. I was wondering if anyone knows the answer to this question:
I have one of those 3-1/2 in routers with the clever push button spindle lock. (Masterforce) Will this lift raise the body high enough above the table to use it? There is no spindle nut.
Thanks!
-- The problem with communication is the illusion that it has occurred. – George Bernard Shaw
7 replies so far
View Rich's profile
Rich
3751 posts in 762 days
#1 posted 02-10-2018 05:09 PM
It depends on the location of the spindle lock button. The throat opening for the lift is 3-3/4”, so if you have to lift it far, there won’t be room to get your finger in there. However, you should be able to orient the motor in the lift in such a way that you can reach it from underneath the table.
View Desert_Woodworker's profile
Desert_Woodworker
1623 posts in 1387 days
#2 posted 02-10-2018 05:18 PM
Good Luck getting “resonanalable” customer service- if interested PM me.
-- Desert_Woodworker
View pottz's profile
pottz
3343 posts in 1157 days
#3 posted 02-11-2018 08:55 PM
I have the jess em master lift and I love it,the quality is excellent and have never had an issue.cant answer your question accurately on the router you have I’m using a porter cable in mine.you should probably contact jess em and I’m sure they can inform you better.also id recommend there clear cut stock guides,also high quality and work very well.
View johnstoneb's profile
johnstoneb
3033 posts in 2345 days
#4 posted 02-11-2018 09:18 PM
The lift will not lift the body above the table. You might be able to engage the spindle loc depending on its location on the body.
-- Bruce, Boise, ID
BenDupre
#5 posted 02-24-2018 09:30 PM
Amswered. Works perfectly.
View BG43017's profile
BG43017
14 posts in 2861 days
#6 posted 02-25-2018 02:01 AM
Ben,
Did you use the router plate template from Jessem to fir lift in tour table or did you make your own template?
Thanks
BenDupre
#7 posted 02-25-2018 02:27 AM
Ben,
Thanks
- BG43017
I bought a template at the woodcraft store because it was only $15. For that price it saved me a lot of work and it was worth it. It was a Woodpecker template though.
