Planer technique question.
Forum topic by Betsy posted 263 days ago 136 views 0 times favorited 5 replies Add to Favorites
View Betsy's profile
Betsy
1886 posts in 433 days
263 days ago
Topic tags/keywords: planer rough sawn lumber
This is one of those questions that I’m afraid to say what I think for fear of really having mud on my face!
So here’s the question, please tell me your opinion.
When is a rough sawn board ready for the planer? (Take into account using a jig to straighten one edge.)
I look forward to your opinions and will use the majority rule to tell me what to do.
Thanks fellow LJs.
-- Betsy - GO BUCKS!
View GaryK's profile
GaryK
8558 posts in 525 days
263 days ago
Hello Betsy,
Straightining the edge is done after the board has already been planed.
You will need to joint one surface flat.
Here is one method: http://lumberjocks.com/topics/1992
Another is to use a planer sled with shims or wedges under the board to keep it steady while planing
one surface.
Use the search feature on this website. This has been discussed many times.
Betsy
263 days ago
I understand that one side has to be flat before it can be planed to thickness. (I learned that the hard way.) However, if you have jointed, either by power jointer, router sled (by the way, Gary, that’s quite a sled!) or hand plane, when is flat, flat enough?
For instance, if the board lying on a known flat surface does not rock, is it flat enough for the planner?
If the board still has rough spots after jointing, but sits flat is that flat enough?
I’m not sure I’m asking this question right – but we’ll get there I’m sure.
GaryK
263 days ago
Ah, well that’s different. If it doesn’t rock it’s good enough for the planer.
Just make sure that it doesn’t just sit on the 4 corners though. It could be bowed and not rock.
Betsy
263 days ago
Hallelujah!
That’s what I wanted to hear!
Thanks Gary.
View jeffthewoodwacker's profile
jeffthewoodwacker
206 posts in 341 days
263 days ago
Flat, level, and square are figments of the imagination. Just kidding. I would agree with Gary if you have got one side flat on a jointer you are ready for the planer. You could have a few rough spots after jointing but if it sits flat run it through the jointer. You can always put a straight edge, winding sticks or your other favorite way of making sure that it is flat.
-- Genius is immediate, but talent takes time.
Bookmark And Share This Page
