Stone Grinding Wheel Restoration
« back to Hand Tools forum
Forum topic by MrWhit posted 02-10-2018 03:46 PM 456 views 0 times favorited 6 replies Add to Favorites Watch
View MrWhit's profile
MrWhit
18 posts in 840 days
02-10-2018 03:46 PM
Topic tags/keywords: sharpening tools restoration grinding wheel treadle power
Just got a nice grinding wheel that I’m looking to build a frame and treadle for. I need to mount the axle. I can’t find what I’m looking for online because I don’t know the name. It looks like a bearing that splits in two and screws down on the mount. I heard the term Babbitt bearing, but nothing close to a replacement comes up online thoughts?
View bandit571's profile
bandit571
20744 posts in 2770 days
#1 posted 02-10-2018 03:56 PM
May have found one you might like…
A few blocks from my house….
View Loren's profile
10477 posts in 3734 days
#2 posted 02-10-2018 04:12 PM
Babbit is a metal alloy that is poured in molten
form around a shaft in place. It’s like a custom
bushing. I don’t think that’s what you need
for a grinding wheel.
You might be looking for “pillow blocks”. For
a slow thing like that wheel you could make
your own out of hard maple or similar and they
would last a long time.
View Woodknack's profile
Woodknack
12246 posts in 2466 days
#3 posted 02-11-2018 01:05 AM
Split Bushings maybe. But I agree with Loren, make some from hardwood, an oil tropical wood would be best but hard maple will work too.
View CaptainKlutz's profile
CaptainKlutz
395 posts in 1581 days
#4 posted 02-12-2018 04:48 PM
Hmm,
Suspect the technical name you seek is:
(split) pillow block bearing
Pillow Block bearings are not cheap units and typically designed for heavy duty applications.
Suggest the reason a babbit bearing was suggested is due cost .vs. simple low speed application. For a hand/foot powered grinding wheel a simple bronze/lead bushing would last many years.
Modern equivalent for babbit bearing today is oil impregnated bronze bearing. I like to use MSCDIRECT for this kind of stuff, but McMaster or Grainger carry them as well.
Brass and oil impregnated bronze stock is super easy to machine. You can also buy plain bar stock to make any custom size bearings you need and then simple press them inside a wood/metal housing.
Best Luck.
MrWhit
#5 posted 02-12-2018 05:51 PM
Thanks guys! Split Pillow Block is what I was looking for, but I ended up using hard maple and so far so good. We’ll see how long it lasts.
View John Smith's profile
John Smith
1256 posts in 249 days
#6 posted 02-12-2018 05:59 PM
I poured some babbitt on an old Hit & Miss motor years ago.
if you have the bearing blocks, there not much to it.
there are probably YouTube videos on how to mold and pour babbitt bearings.
there is a pair of vintage Line Shaft Pillow Block Babbitt Bearings for $10.00 on E-Bay.
-- Graduated Valedictorian from the University of HardKnocks --
