Forum topic by Howie posted 04-07-2011 02:42 PM 1135 views 0 times favorited 9 replies Add to Favorites Watch
View Howie's profile
2656 posts in 2853 days
04-07-2011 02:42 PM
What percent do you consider being too high to varnish a piece?
-- Life is good.
9 replies so far
View Bill Davis's profile
Bill Davis
226 posts in 3854 days
#1 posted 04-07-2011 03:25 PM
I’m not sure there is a maximum humidity for applying varnish. That is unless the specific product has a requirement. Be aware though that higher humidity does slow curing as does low temperature. I have read a minimum temperature for applying varnish. That being 60 deg F.
View juniorjock's profile
1930 posts in 3696 days
#2 posted 04-07-2011 04:06 PM
Howie, are you asking about the humidity in the air or the moisture percentage in the lumber?
- JJ
View Carl Webster's profile
Carl Webster
82 posts in 2728 days
#3 posted 04-07-2011 04:09 PM
I’ve lived in the South all my years and everything that I’ve built furniture wise has been finished with varnish/poly. The only problem you will have with high humidity is that it will lenghen the drying time of your finish.
-- Carl in SC
16273 posts in 4148 days
#4 posted 04-07-2011 04:19 PM
Yeah, here in New Orleans you could never finish anything if humidity was a deal-breaker.
#5 posted 04-07-2011 04:30 PM
Junior I was referring to the air. Thanks for asking.
Thanks to all I appreciate the answers. I’ve already stained the piece(china cabinet) one day ago and the humidity today is 92% already. I’m going to poly it today.
-- Life is good.
View GMman's profile
3902 posts in 3628 days
#6 posted 04-07-2011 04:44 PM
Howie I use Latex varnish and I try to wait for a rainy day to apply, it takes longer to dry but you get a great finish.
So I would go for high humidity.
View Woodwrecker's profile
4128 posts in 3506 days
#7 posted 04-07-2011 06:53 PM
In another month, I bet it’s going to be so humid in Seffner, that drying times will be doubled from what they are right now.
I know in Kissimmee that when the humidity gets nuts, my stuff stays tacky for what seems like forever.
Just move it to the side and get busy on your next project Howie ! LOL
-- Eric, central Florida / Utor praemia operibus duris
#8 posted 04-07-2011 08:00 PM
I keep a de-humidifer in the shop going 24-7 and even with that, it will go up to around 75% now and then. Especially on rainy day. Seems like it’s higher early in the morning and then gradually goes down to about 40%. Like everyone else said, you’ll probably be okay, but the drying time and time between coats will be longer.
- JJ
View Steven H's profile
Steven H
1117 posts in 2990 days
#9 posted 04-08-2011 02:47 AM
75 degrees and 50% humidity.
