Handsaw plate too hard to file
« back to Hand Tools forum
Forum topic by coopersdad posted 02-09-2018 02:36 AM 466 views 0 times favorited 2 replies Add to Favorites Watch
View coopersdad's profile
coopersdad
32 posts in 1039 days
02-09-2018 02:36 AM
Anyone run into a saw plate that was hardened too much to sharpen? I decided to sharpen a Disston miter box saw, around 1900 or so by the medallion and handle. The new Bahco mill file I use for jointing would skate and hardly cut, and when I looked at the file, I was dulling it badly – visible shiny streaks and I could see tooth damage. A dozen passes on the plate and there’s barely a flat spot. The area about a third of the way back from the toe is hardly touched, and I can feel the difference there in filing, it really skates over it. I tried another file I know cuts well, same thing.
This saw appeared to have been used little if any, with only rust from sitting around.
2 replies so far
View TheFridge's profile
TheFridge
10705 posts in 1684 days
#1 posted 02-09-2018 02:42 AM
Try posting to this forum if no answer. This is where the Jedi masters hang out.
http://lumberjocks.com/topics/27984
I’ve heard some use a diamond file for a couple of hard teeth. All or most of the teeth is a different story.
View Ben1957's profile
Ben1957
2 posts in 402 days
#2 posted 02-18-2018 01:23 PM
If it’s a modern saw it can’t be sharpened, steel is too hard and designed to throw away
-- Ben, South Carolina, The creation of sawdust and shavings is my greatest skill in the work shop!
