Dust Collection Duct Design
Forum topic by Joel J posted 02-09-2018 02:26 AM 822 views 0 times favorited 5 replies Add to Favorites Watch
View Joel J's profile
Joel J
48 posts in 2180 days
02-09-2018 02:26 AM
I have a HF Dust Collector that I have added a Thien separator and a 12” Rikon impeller. When I designed my separator, I set it up for a 5” main trunk line, thinking I would use 5” spiral duct and (3) 5×5x4 wyes. The main trunk would be mounted to the ceiling in my garage. I would then use 4” blast gates and 4” flex hose (off the wye) to my table saw, my planer and other tools such as a band saw, spindle sander and 12” disc sander all with 2 1/2” ports. In looking at all my options, now that I am ready to make the purchase, I am cringing at the cost of the wyes. Would/could I use the Woodcraft plastic wye in this setup? I have attached a link below and it seems like I could save some money. Does anyone know what the ID of 5” spiral pipe is? Any thoughts would be really appreciated. Thanks.
https://www.woodcraft.com/products/5-inch-x-5-inch-x-5-inch-y-dust-collection-fitting?via=573621bd69702d0676000002%2C576455d369702d2f2f0013a2%2C5764563569702d3c42000bea
-- Joel, Denver, CO
5 replies so far
View John_H's profile
John_H
190 posts in 1947 days
#1 posted 02-09-2018 08:18 AM
I bought one of those ‘Y’s along with a couple of aluminum blast gates and some other fittings from Woodcraft last week – they are having a 25% off sale right now
I never wanted to get into having a ‘permanent’ type setup with trunk lines running everywhere – instead, I use a single 5” flex hose to connect to my combination machine (jointer/planer/shaper/table saw) which really simplifies things. Recently I got a great deal on some more 5” flex hose from Amazon Warehouse so I decided to add a second 5” flex hose – which is why I bought those parts from Woodcraft
I just finished installing it a couple of days ago, so I don’t have a lot of use with it yet, but so far it has worked out great. I have a single piece of 5” metal duct coming off the dust collector and the end of the 5” Woodcraft Y slipped snugly inside. I also wanted to add two blast gates at the Y – which is when I started to run into problems.
The outside diameter of the end of the Y are about the same diameter as the blast gate so you need some sort of union/coupler. Probably most people would use flex hose or whatever. I wanted something a little more rigid and would not take up a lot of space, so I grabbed my heat gun and with a little patience I was able to heat up the ends of the Y so that they became soft enough that I could force the fitting on the blast gate inside. I then screwed the two parts together with self tapping screws and it feels real solid.
Another problem crept up was I wanted to use a ‘quick connect’ type fitting directly to the blast gate because I don’t always have a hose connected. But, the standard 5” quick connect type fittings I also bought, were a little too big. I was able to work around it by using 4” rubber Fernco connectors (about $7 each on Amazon). So one end of the Fernco goes over the blastgate fitting and is held in place with a worm clamp and the quick connect fitting then goes over the rubber end of the Fernco for a pretty tight friction fit.
So in this pic you can see the Fernco on the upper blast gate (they come with worm clamps) and on the lower blast gate I have my 5” flex hose with the Woodcraft 162288 quick connect coupler attached to the other Fernco
Woodcraft also has a 5” to 4” connector if you wanted to do something similar with your 4” hose (162287)
View d38's profile
d38
108 posts in 503 days
#2 posted 02-09-2018 02:14 PM
Joel,
Since spiral pipe is expensive, look at heavier gauge snaplock.
For my Grizzly 2 hp, I used 26 ga Greenseam brand thru Grainger. They also have 24 ga. Purchased in boxes of 5 pieces. It has a neoprene-type of product in the snap and on the tube ends for better seal, but other than that, its snaplock. If you can pickup at a store, its very reasonably priced.
https://www.grainger.com/product/GREENSEAM-Snap-Lock-Pipe-6PGC8
I got my saddles and elbows from Air Handling Systems, in their “hobby” product line.
Good prices, but shipping is pretty high – call for a shipping quote. They’re very helpful.
https://airhand.com/product-category/woodworking-hobby-shop-light-gauge-solution-for-spiral-pipe-fittings-and-hose/
I used Menards band clamps to connect a lot of it. Great for connecting 2 male fittings. Its nothing more than sheet metal with hose clamp ends riveted to it. Add some sheet metal screws like John posted above, and you’re set.
https://www.menards.com/main/heating-cooling/ductwork/ductwork-fittings/drawband-duct-fitting/01504010rb/heating-cooling/ductwork/ductwork-fittings/drawband-duct-fitting/01505010rb/p-1444432213590.htm
Duct is a jigsaw puzzle to figure out a good design, but in the end, you’ll enjoy it
Joel J
#3 posted 02-09-2018 11:29 PM
Thanks guys….some great ideas there. I guess I’ll just need to get back on that jigsaw puzzle!
-- Joel, Denver, CO
View Holbs's profile
Holbs
2041 posts in 2271 days
#4 posted 02-10-2018 01:56 AM
are 5” wye’s more spendy than 6” wye’s? If I remember right, my 6” metal duct wye’s were around the $12 at a local HVAC distributor with 26 gauge. They were about the same at HD but 28 or some 30 gauge.
I did buy ALOT of 26 gauge HVAC ducting for my shop but also some trashed 6” green PVC SWD pipe that easily molds after heat gun treatment.
View Rayne's profile
Rayne
1126 posts in 1781 days
#5 posted 02-10-2018 02:49 AM
are 5” wye s more spendy than 6” wye s? If I remember right, my 6” metal duct wye s were around the $12 at a local HVAC distributor with 26 gauge. They were about the same at HD but 28 or some 30 gauge.
- Holbs
Yes, they are. I’m thinking they’re not used very often, so not widely made. I hunted all over the place for a 5” wye and ended up spending about $30/ea from a store in Texas when I was setting up mine. I found 5” T’s on the cheap, but that would have killed my CFM.
