Best marking gauge?
Forum topic by kent_michaels posted 773 days ago 4128 views 0 times favorited 7 replies Add to Favorites Watch
View kent_michaels's profile
kent_michaels
34 posts in 858 days
773 days ago
I’m looking to get my first marking gauge and wanted some opinons from you guys. My top choices are either a veritas wheel marking guage, or a crown mortise/marking gauge. Although i’ve read on some forums that the harbor freight marking guage is a good beginers tool to purchase and is basically the exact same as the crown. Thanks for any help guys.
http://www.leevalley.com/US/wood/page.aspx?p=59455&cat=1,42936
http://www.rockler.com/product.cfm?page=20371&filter=marking%20gauge
http://www.harborfreight.com/6-inch-mortise-gauge-94645.html
7 replies so far
View drewnahant's profile
drewnahant
218 posts in 1255 days
#1 posted 773 days ago
the mortise gauges are nice, having the two cutters, but I think that in general the wheel gauges are better, they work much nicer going across the grain, because they dont tear the grain the way the little pin does on a mortise gauge. If you can get a mortise gauge with the blade style cutter, that should work well( I have never used one, but seen them). woodcraft has a less expensive wheel marking gauge the veritas is certainly a bit nicer, but either is a good tool to start, and a mortise gauge will be a good addition down the line if you find that you ar marking a lot of double lines for mortises, tennons, dadoes, etc.
View JuniorJoiner's profile
JuniorJoiner
441 posts in 1606 days
#2 posted 773 days ago
a marking gauge is a layout tool,and should be quality if you want to do quality work
I recommend
http://play-glen-drake.com/v-web/ecommerce/os/catalog/product_info.php?cPath=24&products_id=37&osCsid=6d893580f46ccfe16640749653e7a53a
what I use
-- Junior -Quality is never an accident-it is the reward for the effort involved.
4872 posts in 1814 days
#3 posted 773 days ago
I’m not wild about the gauges with the pins. I prefer the style with
a knife. I have a bunch of marking and mortise gauges – they can
be left setup for a particular joint you make several times on a piece,
so it’s worth buying old ones when you find them at flee markets
and such.
View HoBoMoNK's profile
HoBoMoNK
1381 posts in 2294 days
#4 posted 773 days ago
I have one of these from Lee Valley.
I prefer the Japanese kebiki. Here’s two from Lee Valley.
Here’s where I generally order Japanese tools: Japan Woodworker.
-- 温故知新
View GregD's profile
GregD
597 posts in 1302 days
#5 posted 773 days ago
I have been happy with this one from Rockler. I doubt that it’s “the best”, but still a solid performer.
-- Greg D. -- the price of freedom is tolerance
View Tedstor's profile
Tedstor
924 posts in 799 days
#6 posted 773 days ago
Now don’t get me wrong here, I’m not a HF hater. I have lots of their stuff and I’m satisfied with the vast majority of it. So with that said….....
The HF mortise gauge I bought was 1000% crap. The beam was warped, and even if it weren’t, the mortise that the beam rides in was drilled at a 10* angle. I’ll definitely be hesitent to buy something like that online again.
I bought a rockler wheel/cutting gauge when they were marked down to $7.50, and am happy with it. However, I’ll probably upgrade to the Veritas wheel gauge at some point. The Veritas looks to be a few notches up from the rockler in terms of quality and performance.
View 000's profile
000
3352 posts in 783 days
#7 posted 773 days ago
Make one. It’ll be yours alone, and you’ll like it.
-- When the moderator chooses sides, his site sucks.
