turning a spoon rest
« back to Woodturning forum
Forum topic by Karda posted 02-08-2018 06:56 AM 1280 views 0 times favorited 16 replies Add to Favorites Watch
View Karda's profile
Karda
1106 posts in 577 days
02-08-2018 06:56 AM
I want to make a plate I am turning into a spoon rest, how would I make the cut in the side, also do I do it before or after I turn the plate thanks
16 replies so far
View Nubsnstubs's profile
Nubsnstubs
1296 posts in 1753 days
#1 posted 02-08-2018 03:13 PM
Go to youtube and search Brendan Stemp. I believe he has a video, but if not, the suggestions page probably has one for you….. Jerry (in Tucson)
View Lazyman's profile
Lazyman
2043 posts in 1410 days
#2 posted 02-08-2018 03:22 PM
It is not clear to me what the cut in the side is for. A little more info would help.
View John Smith's profile
John Smith
993 posts in 186 days
#3 posted 02-08-2018 06:50 PM
a photo or simple drawing of what you have now – and what your plans are will help a lot.
for me personally, anything turned on a lathe that has any alterations in the sidewall
should be hand cut after all the turning is done. not before or during the turning process.
-- Graduated Valedictorian from the University of HardKnocks --
Karda
#4 posted 02-08-2018 07:22 PM
Ok Jerry I have never seen a spoon rest, I should have searched first but I always forget still training myself to do go to utube first. The cut in the side is so the spoon will stay in the bowl instead of rolling off onto the counter
John Smith
#5 posted 02-08-2018 08:27 PM
something along these lines would require the spoon notch to be cut after
all the plate/bowl turning is said and done.
use the same food safe oil as you would with any plate, bowl, cutting board, etc.
as this is an item that will come in direct contact with food constantly.
Karda
#6 posted 02-08-2018 08:41 PM
ok thanks I’ll do it after
John Smith
#7 posted 02-09-2018 03:39 AM
after you get your plate turned, post some photos if you are not sure how to cut the notch.
I would probably use a coping saw for the initial cut then some rasps, files, round sanders,
(round sanders = various grit sand paper glued to PVC pipe of various sizes).
carving knives, whatever it takes to get it just right. then apply the cutting board oil of your choice.
Karda
#8 posted 02-09-2018 05:52 AM
here are the pictures you requested neither one is over 5”
Nubsnstubs
#9 posted 02-09-2018 02:43 PM
- Karda
Hmmmm, invisible spoon rest. very good….. Jerry (in Tucson)
View MrUnix's profile
MrUnix
6764 posts in 2222 days
#10 posted 02-09-2018 03:45 PM
- Nubsnstubs
I think he removed a bit too much :)
Lazyman
#11 posted 02-09-2018 03:54 PM
Personally, I don’t think you need to worry about cutting a notch out of the side. If you simply make it with a slight depression without the raised sides, there is no need to cut out a notch, sort of like a coaster for a spoon. Like this but could be any shape (round, square, etc.). My 2 cents.
Karda
#12 posted 02-09-2018 04:49 PM
I have been using the dark one and a straight wooded spoon keeps falling off, curved are ok
Nubsnstubs
#13 posted 02-10-2018 01:39 PM
- Nubsnstubs
- MrUnix
Brad, you have a humorous side I haven’t seen before… Oh Oh, I have rto retract that. remember CONTRAPTION? hehehe
Mike, in post #8 you indicated you were gonna post pictures. Nope, none there, Bud…. I tried subtly to alert you to that fact, and Brad even chimed in, but still, No Pictures!. Wassup wid dat, man?........ Jerry(in Tucson)
Karda
#14 posted 02-10-2018 04:10 PM
sorry guys I don’t take hints well, all I can do is plead coffee defitianscy heres the pics this time
John Smith
#15 posted 02-10-2018 05:03 PM
very nicely done Karda.
if I were doing it, I would carefully cut the notch out with the coping saw,
using whatever tools you have available, make the notch as smooth as the dish,
treat with your choice of cutting board/dish/bowl oil and throw a spoon in it
saturated with old fashioned country gravy !!!
I have several wooden spoons made of maple and bamboo that are over 40 years old
and none of them have EVER been oiled with anything. a personal choice, I guess.
