Pen Turning Mandrel Question
« back to Woodturning forum
Forum topic by JMillerWoodworks posted 02-08-2018 02:33 AM 425 views 0 times favorited 5 replies Add to Favorites Watch
View JMillerWoodworks's profile
JMillerWoodworks
50 posts in 546 days
02-08-2018 02:33 AM
Topic tags/keywords: question lathe turning
I am new to turning pens and currently have been using a 7mm mandrel. I would like to get into turning the bolt-action pens; which are 3.8” barrel. However, I have yet to see a 3.8” mandrel. I have found many other sizes, but not this size. Is there a metric millimeter mandrel that is equivalent to a 3/8 inch or do I need a labeled 3/8” mandrel? If I do need a 3/8” mandrel, can you recommend a company that sells this size.
-- - Joel Miller "Striving to be like the Carpenter of Galilee"
5 replies so far
View woodbutcherbynight's profile (online now)
woodbutcherbynight
5686 posts in 2608 days
#1 posted 02-08-2018 02:39 AM
Normally the site that sells the kits also sells the mandrels and other accessories. What site and what kit are you looking at?
View Ripper70's profile
Ripper70
1163 posts in 1108 days
#2 posted 02-08-2018 02:43 AM
If I’m not mistaken, the mandrel stays the same. It’s the bushings that change to adapt to the pen blanks that you turn. There is a pen turning forum that would be worth joining if you’re just getting started in this endeavor. I’m sure you’ll find answers to all your questions there.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
JMillerWoodworks
#3 posted 02-08-2018 02:52 AM
Thanks for the info! Now that I look it up online (I had been looking at a PSI catalog) I see that the 30 caliber bolt action pen is a 7mm. The one question that I have is if it uses a 7mm mandrel; then how come you used a 3/8” drill bit? 7mm is equivalent to 1/4”. Is the barrel actually 1/8” thick to made up for the difference of the drill bit? Thanks for commenting!
Ripper70
#4 posted 02-08-2018 03:24 AM
See here for an assortment of bushings and here for the Bolt Action Pen Kit bushings.
View bbasiaga's profile
bbasiaga
1240 posts in 2194 days
#5 posted 02-08-2018 03:45 AM
Yes, there will be a set of bushings listed with your pen kit. Those bushings will slide over the 7mm mandrel, and have a small section that fits inside the tube of the pen kit, and a larger section that marches the diameter you turn the blank to in order.to match up with the pen’s hardware.
This way, you use one mandrel for all different kits, and the matching set of bushings for each. Lots of examples on YouTube.
Brian
