Good glue to use?
Forum topic by TheCrater posted 04-06-2011 03:05 PM 2223 views 0 times favorited 11 replies Add to Favorites Watch
View TheCrater's profile
TheCrater
3 posts in 2693 days
04-06-2011 03:05 PM
Hey guys, I’m just wondering what type of glue you guys use for your projects. I’ve used titebond and elmers wood glue before, but I would like something with a clear finish. Something almost like super glue. I searched my local HomeDepot but didn’t have much luck finding anything. Any suggestions? Thanks guys.
11 replies so far
View ScottN's profile
ScottN
261 posts in 2764 days
#1 posted 04-06-2011 03:40 PM
I’ve never heard of a clear glue for wood.
-- New Auburn,WI
117175 posts in 3662 days
#2 posted 04-06-2011 03:49 PM
White glues dry clear.
View Bertha's profile
Bertha
13529 posts in 2778 days
#3 posted 04-06-2011 03:57 PM
I use Titebond III on most everything. I’ll occasionally use gorilla glue if I need to fill a gap. I’ll occasionally use CA glue on lathe projects. I’ve experimented with hide glue but that doesn’t sound like what you’re after. As long as my joint is tight & I clean up squeeze out, I’ve never had trouble with Titebond III. I think that’s the most common general glue around here.
Craftsman on the lake
2799 posts in 3522 days
#4 posted 04-06-2011 04:03 PM
white glue dries clear but you have to scrap it off. It’s doesn’t sand. Yellow glue sands. If there is any stain going on the wood both will show if not removed so the yellow glue is the choice.
I remember seeing a video about 30 years ago where they cut a 2×4 lapped it and glued it together. They put pressure on it and it always broke someplace else besides the glue joint. It was tested for military purposes and found to be the strongest glue for porous materials like wood at the time. Now I’d think that titebond is sort of an upgrade from that. Cool stuff.
View childress's profile
childress
841 posts in 3626 days
#5 posted 04-06-2011 06:01 PM
Roo glue makes a Roo Clear that I use for melamine. I thought it was designed for non-porous materials (hence, melamine, laminate) but they state you can bond all kinds of things including regular wood to wood. I’ve never tried it in that application, but it’s worth a shot.
-- Childress Woodworks
View gfadvm's profile
gfadvm
14940 posts in 2774 days
#6 posted 04-07-2011 04:29 AM
Titebond makes a trim and cabinet glue that dries clear ,is thick enough that it wont run,and has a very fast tack time.
View bubinga's profile
bubinga
861 posts in 2752 days
#7 posted 04-07-2011 05:45 PM
You can also get dark wood glue ,to use on ,,,for example ,,walnut
-- E J ------- Always Keep a Firm Grip on Your Tool
#8 posted 04-07-2011 08:53 PM
I’ve used white glue for years on finished material and wipe of any excess so it does not have to be sanded. I’ve also used clear Roo glue where I need more flex For most projects I use Tite bond. Depending on what you use it for some glues work better than others.
View Steven H's profile
Steven H
1117 posts in 3145 days
#9 posted 04-08-2011 02:15 AM
Is there a particular reason why you need it clear?
View juniorjock's profile
juniorjock
1930 posts in 3850 days
#10 posted 04-08-2011 02:21 AM
Are you asking if the finish isn’t doing well around where your glue joints are?
- JJ
View wseand's profile
wseand
2796 posts in 3126 days
#11 posted 04-19-2011 05:25 AM
Sorry wrong thread…..
