Tenoning Jigs
Forum topic by therookie posted 04-05-2011 05:23 PM 4204 views 4 times favorited 10 replies Add to Favorites Watch
View therookie's profile
therookie
887 posts in 2825 days
04-05-2011 05:23 PM
I am building my mom a barristers bookcase for mothers day and there are a lot of mortise and tennon joints. I thought about doing them on the bandsaw but I figured if I could get a tenoning jig they might come out better. I was wondering the best brand of jig and the thoughts from others weather or not I should save my money and do them on the bandsaw. Thanks
-- http://aewoodworks.webs.com
10 replies so far
View richgreer's profile
richgreer
4541 posts in 3073 days
#1 posted 04-05-2011 05:26 PM
I think you will get better tenons on a TS with a tenoning jig. However, tenoning jigs are not hard to make. I’d suggest that you consider making your own. There are lots of plans available (for free).
View lew's profile (online now)
lew
12059 posts in 3753 days
#2 posted 04-05-2011 05:46 PM
Adam,
Check out these links
http://www.woodmagazine.com/woodworking-plans/tablesaw/shop-made-tablesaw-tenoning-jig/
http://www.popularwoodworking.com/projects/tablesawtenonjig
http://woodgears.ca/tablesaw/tenon_jig.html
Lew
BTW- why aren’t you in school ;^)
therookie
#3 posted 04-06-2011 04:12 AM
Lew I am on spring break right now….. lol
therookie
#4 posted 04-06-2011 04:23 AM
oh yeah and thanks for the links.
View Loren's profile
10390 posts in 3646 days
#5 posted 04-06-2011 05:13 AM
The bandsaw works great for tenons.
You don’t need a table saw jig to do them.
I usually bandsaw the cheeks and use a router table and an
end-mill to clean them up and make subtle thickness adjustments.
The router table can be used to refine the shoulders as well.
I learned this method from books and articles by Gary Rogowski.
View NathanAllen's profile
NathanAllen
376 posts in 3142 days
#6 posted 04-06-2011 04:52 PM
I have a Delta 34-184, two disadvantages on the manufactured jigs are blowout and width restriction.
To compensate for blowout: You use up a lot of scrap to provide backers.
To compensate for width restriction: You end up having a reference block the same height as the base to position your stock.
For haunched tenons you’ll still end up using a band saw or handsaw to create the haunch.
The Jet, Grizzly and Woodriver are all comparable, the only major differences are where the push handles are located. I like the Delta because my hands stay out of the way of the blade.
Once your dialed in through you can cut the cheeks on a tenon in about half a minute and run through all of them in one quick session.
The other main requirement is a good dado stack, so not a cheap solution but a good tenon jig will outlast you since they only see infrequent use.
Another side of the equation is making sure you have consistent mortises, again not a cheap solution but a dedicated benchtop mortiser again allows you to setup then produce large quantities in a short amount of time.
In the end though it all depends on your skill level, budget and time. Hand-cut tenons and mortises are amazing, same a dovetails, but the amount of time required to learn the skill is high. You’ll also need to have a reliable workbench to secure the piece, a marking gauge and patience. Building your own jig can be a very rewarding experience; but since you can puchase a tenon jig for around $100 it isn’t a major cost savings, at least when you factor in the time you’ll spend making the jig.
There are many ways to create T&Ms, finding one that works with you; skill level, budget and time. Just thought I’d play devil’s advocate for those who go the quick route.
View Pyamed's profile
Pyamed
30 posts in 2691 days
#7 posted 04-06-2011 05:55 PM
View Bertha's profile
Bertha
13528 posts in 2691 days
#8 posted 04-06-2011 06:20 PM
^yeah, that’s one good way to go (Leigh, lol). I built a simple tenon jig for my tablesaw using a couple of toggle clamps & some plywood. Worked great. So, I had to mess with something that was working & bought the Rocker tenon jig. I was THIS close to buying the JET with the quick-release but my shopping cart was overflowing and the Rocker (WoodRiver I’m guessing) was only $89.00. It’s well constructed with good surfaces but it’s VERY heavy. You won’t be hanging this jig on your pegboard. It has really fancy fine-adjust controls and works well. $89 better than my homebrew? Not really. I’d build a really nice homebrewed jig if I were you. Good luck.
therookie
#9 posted 04-07-2011 07:48 PM
thanks for all of the feed back everyone. I think that I will end up building a home made tenoning jig so I can get the frames done on this bookcase.
Bertha
#10 posted 04-07-2011 08:10 PM
I took some pictures of the Rockler jig so you can have an idea how it works. It’s pretty inexpensive if you decide to go this route but I searched “tenon jig” on lumberjocks and found so many homebrews that I’d rather have.
Here’s my simple 1 hour jig on a $99 tablesaw
