epoxy whitens on drying
« back to Woodturning forum
Forum topic by Karda posted 02-07-2018 01:00 AM 420 views 0 times favorited 20 replies Add to Favorites Watch
View Karda's profile
Karda
1075 posts in 552 days
02-07-2018 01:00 AM
Hi I have a knot with a crack in it that is to big for CA so I mixed up some clear epoxy but when it dried it dried white. is there a clear epoxy that drys clear, I used Devcon
20 replies so far
View swirt's profile
swirt
2737 posts in 2970 days
#1 posted 02-07-2018 02:29 AM
Amazing Clear Cast stays clear [amazon link]. It is slow setting so gives air bubbles more of a chance to get out.
It is hard to say whether yours turned white because it cures that way, or because it just cured fast and ended up with a lot of air bubbles.
View Snowbeast's profile
Snowbeast
80 posts in 1337 days
#2 posted 02-07-2018 03:24 AM
Can’t offer any advice on epoxy but I will offer a different approach to crack filling.
Try packing the crack/hole with fine sanding dust and then drenching with CA. It will harden nicely and turn a very dark brown or black. It can be sanded smooth and it’s very difficult to tell that a repair was made.
This works well with dark woods or knots but the crack line is visible on lighter woods. Can be used as an accent feature, if desired.
View johnstoneb's profile
johnstoneb
2915 posts in 2171 days
#3 posted 02-07-2018 03:27 AM
Pictures always help
-- Bruce, Boise, ID
Karda
#4 posted 02-07-2018 04:39 AM
I thoght of that but I am working on a maple piece the knot is dark brown, no dust that color. Nothing can be that easy for me
View Rich's profile (online now)
Rich
2824 posts in 588 days
#5 posted 02-07-2018 05:06 AM
The sanding dust/CA glue method mentioned earlier works great. Be sure to use thin CA. You can also get colored pigments for your epoxy to help blend in with where you’re applying it. System Three makes some, or you can use Mixol pigments available at Woodcraft.
Finally, epoxy putty is available in many colors that can be blended to further extend the color range. They are stable and sand easily.
Karda
#6 posted 02-07-2018 05:16 AM
i have been thinking of colored epoxy. I had a nice piece of eucalyptus with some large craks I used thick CA but black would have been nice withe the red patterned wood
View MrUnix's profile
MrUnix
6714 posts in 2197 days
#7 posted 02-07-2018 05:21 AM
For that dark brown knot, mix your epoxy well, then add in some used coffee grounds. You can tint epoxy with any number of things you may have around the house.
Rich
#8 posted 02-07-2018 05:27 AM
- MrUnix
French or Italian roast?
Karda
#9 posted 02-07-2018 05:48 AM
i would if I could but I don’t drink coffee at home. maybe can con the waitress out of some
Rich
#10 posted 02-07-2018 05:56 AM
i would if I could but I don t drink coffee at home. maybe can con the waitress out of some
- Karda
You could go dumpster-diving out back of your local Denny’s. Just don’t get caught. It’d be hard to explain.
Edit: On second thought Starbucks might offer a wider array of grounds to choose from. It could become your signature look.
MrUnix
#11 posted 02-07-2018 06:16 AM
- Karda
It doesn’t have to be used… I just hate wasting good coffee :)
You can color epoxy with just about anything. Chalk works well and can be had in a ton of different colors. Sawdust works as well, and will be darker than original. Metal shavings, crushed rock, various spices found in your cabinet, talcum powder, graphite (from pencil shavings), many paints, inks and dyes, shredded fabrics, aluminum foil, etc… just use your imagination and if unsure, test a small sample first.
Karda
#12 posted 02-07-2018 06:17 AM
ok but what flavor is best.
Rich
#13 posted 02-07-2018 06:38 AM
- MrUnix
Honestly, you’re joking, right? This is LumberJocks, not Martha Stewart.
Like I said, there are pigments for epoxy that you can blend to any color.
MrUnix
#14 posted 02-07-2018 06:45 AM
Honestly, you re joking, right?
- Rich
Nope.. dead serious – they all work and work well. Coffee however is probably the most common.
View Tony_S's profile
Tony_S
867 posts in 3082 days
#15 posted 02-07-2018 11:28 AM
Your man card has officially been revoked Brad…..Go hang out at Marthajocks fer chrisakes!!
You can teach them how to change out the bearings on their food processors or something ;)
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
