Bench Rabbet Plane
« back to Hand Tools forum
Forum topic by JP4LSU posted 02-06-2018 10:38 PM 493 views 0 times favorited 9 replies Add to Favorites Watch
View JP4LSU's profile
JP4LSU
83 posts in 170 days
02-06-2018 10:38 PM
Topic tags/keywords: plane
Should you buy a Bench Rabbet Plane to get 2 planes in one?
Will it do both jobs satisfactory?
I’m thinking also of buying the block rabbet plane that LN offers and thought would the bench rabbet be a good multiuse plane?
Thanks,
JP
9 replies so far
View Rich's profile (online now)
Rich
2963 posts in 612 days
#1 posted 02-06-2018 11:18 PM
I have the rabbet block plane and find it’s a good compromise. It performs well as a low angle block plane and I also use it to trim tenons.
View TheFridge's profile
TheFridge
9606 posts in 1509 days
#2 posted 02-06-2018 11:30 PM
I wouldn’t get it unless you’re doing wide rabbets a lot. The few I know with a #10 don’t use them often. I’d go rabbeting block. It’ll get much more use.
Rich
#3 posted 02-07-2018 12:26 AM
Fridge has a good point. Even the rabbeting block plane is a bit wide for a standard 3/4 to 1-1/4 inch tenon, and can tend to roll sideways if you’re not careful. I’d imagine the bench version would be even more difficult.
View Loren's profile
10476 posts in 3671 days
#4 posted 02-07-2018 12:31 AM
I had a #10 and a #289 and with both of
them I had trouble making a square rabbet.
I’m sure you get better with practice. I didn’t
mind the idea of using a hand tool for a few
minutes to make the cut instead of messing
with a machine, but my results were worse
than the machine. I also had a #46, same
difficulty with making rabbets.
I still have a shoulder plane for trimming joints.
That I find is a useful tool.
JP4LSU
#5 posted 02-07-2018 12:53 PM
OK thanks guys for the inputs. All valid points. I think I’ll shy away from the rabbet bench plane. I may still end up going for the rabbet block plane though eventually. I can envision more scenarios of its usefulness than the rabbet bench plane.
Maybe a small shoulder and a rabbet block plane would be a good combo.
Thanks again guys. You’ve talked me out of a rabbet bench plane. You’re making me buy 2 tools and spend more money. Congratulations. Haha!
-JP
View LittleShaver's profile
LittleShaver
326 posts in 642 days
#6 posted 02-07-2018 01:25 PM
I have the LV rabbet block plane and it is my go to block plane. The other 8 or 10 block planes on the shelf are jealous.
-- Sawdust Maker
JP4LSU
#7 posted 02-07-2018 09:39 PM
Thanks LittleShaver for the input on the rabbet block plane. Although I didn’t know LV had a rabbet block plane. I was looking at the LN version.
-JP
View knockknock's profile
knockknock
447 posts in 2196 days
#8 posted 02-08-2018 04:56 AM
I’m guessing it’s the Veritas skew block plane:
View bandit571's profile
bandit571
20212 posts in 2706 days
#9 posted 02-08-2018 05:20 AM
What I have been using, lately…YMMV
