Bandsaw ¼" Setup Problems
Forum topic by sretepuk posted 04-05-2011 02:18 PM 1251 views 0 times favorited 4 replies Add to Favorites Watch
View sretepuk's profile
sretepuk
5 posts in 2849 days
04-05-2011 02:18 PM
I seem to have a problem where my ¼” blade comes off the bottom drive wheel, never happens with blades larger than a ¼”.
I have an Axminster 8” (AWHBS350N) a very versatile band saw, most of the time it cuts very well. BUT..
Whenever I fit the ¼” blade and balance the straight cut verses the tension it tracks itself off on the bottom wheel.
I know narrow blades, due to the manufacturing process, naturally track to the front of the bottom drive wheel. But why when I just get the cut and tension just right it decides to jump off?
This used to happen to my Dewalt 739 bandsaw as well so I don’t think its the bandsaw itself.
The only thing I can attribute it to is the tension, but if I use less tension the ¼” blade will not cut true? Anything more than 2” stock cuts with a slight angle and ruins the project I’m trying to make!
Most of the woods I cut are local hardwood’s like Ash, Oak, Cedar etc..
-- Dennis, East Midlands, UK
View lew's profile
lew
12512 posts in 3996 days
#1 posted 04-05-2011 06:12 PM
When my saw did this, I adjusted the tracking so that the blade tracked at the “back” of the top wheel- a little past the center “hump”.
sretepuk
#2 posted 04-05-2011 11:09 PM
Thank you lew, I went out to the shop and gave that a go, so far so good.
View Howie's profile
Howie
2656 posts in 3163 days
#3 posted 04-06-2011 01:21 AM
This is something I can certainly try. I’ve had the same problem with my little 9” Delta. Works fine with a 3/8” but couldn’t keep the 1/4” on. Thanks for the tip.
-- Life is good.
sretepuk
#4 posted 04-06-2011 10:49 PM
Still working ok but I have to admit I don’t have quite the amount of tension on I usually have. What I have found is my feed rate is slower, still cutting straight but with less throughput.
To be honest I’m letter the saw tell me how fast to go, don’t ask me to put numbers on it, it’s a gut feel. Certainly slower down the grain than across it!
