DAILY DEALS Rockler 3-Pc. Roundover/Beading Bit Set at Rockler  |  DeWalt Gauge Narrow Crown Stapler at Tool King
Craftsmen Model 11323881 lathe
Forum topic by kevinw posted 606 days ago 386 views 0 times favorited 15 replies Add to Favorites Watch
View kevinw's profile
kevinw
63 posts in 618 days
606 days ago
Topic tags/keywords: lathe faceplate lathe chuck parts woodturning question
I just picked up an old craftsmen lathe in good shape hoping to learn some lathe work. I have realized that it has no faceplate or chucks with it. Hoping someone can inform me as to a good source for these for this model. Do they have to be made for a specific model or just meet certain specifications. I should have asked this question before buying, but such a lathe newbie I just didn’t think about it.
-- Kevin, Blue Springs, MO
View GaryK's profile
GaryK
9496 posts in 867 days
606 days ago
Attachments are basically interchangable for the most part.
You probably have #2 or #3 morse taper in the spindle and a thread on the outside. I can’t recall the sizes
but it’s a common size.
Others here will be able to tell you for sure.
View WayneC's profile (online now)
WayneC
5857 posts in 976 days
606 days ago
kevinw
606 days ago
Thanks. I will do some more checking. In other words if I took one of my tapers in to a store they could direct me to a faceplate or chuck that would work? Of course, I have plenty of learning and practice to do just on long spindle type stuff with the tail and head and the parts I already have : )
View rikkor's profile
rikkor
11338 posts in 753 days
605 days ago
See if you can locate a wood turning club in your state. You might find a want-ad source through them.
View Dadoo's profile
Dadoo
1724 posts in 869 days
605 days ago
Also try www.partsdirect.com or www.toolpartsdirect.com. Put in your lathe model number and the schematic should show you what you’re looking for and whether it’s available. You could also check for the specific parts on Ebay. And then I’d put the part name into Google and see what they link you to. Every now and then you find an oddball supplier who’s got exactly what you need. Good luck!
View tenontim's profile
tenontim
1319 posts in 623 days
605 days ago
Grizzly has a good selection of lathe parts. I’m not sure of the measurements for all of the tapers, but I know the #1 goes up to 3/4”. I’m not big on turning, so my knowledge is limited.
-- Tim -- http://tmuli.com
kevinw
605 days ago
You guys are great. Thanks for all the good advice.
kevinw
605 days ago
Looks like I have a 1 morse taper (whatever that means : ) rather than a two or three. Is the diameter bigger as the numbers go up? Or down? The schematic from WayneC’s very helpful link does not show a faceplate or chuck as an option, so I guess it will have to be third party or Sears made for another model and happens to work. Does the faceplate or chuck thread on to the spindle or insert in the spindle like the tapers?
Probably some of my questions don’t even make sense as I am not even certain I am using the right terms. Thanks in advance for your patience.
tenontim
605 days ago
Kevin, the numbers go up, ie #2 is larger than a #1. Another source for lathe parts is Penn State Industries.
http://www.pennstateind.com/ Also, if you have any questions, like about morse tapers and such, the tech line at Grizzly is very helpful.
kevinw
605 days ago
I just looked at your chairs. Those are great looking pieces. Thanks for all the tips.
tenontim
604 days ago
Thanks, Kevin. Appreciate it. Also, I found you some information on Morse tapers. #1 tapers from .369” – .475” #2 tapers from .572” – .700” #3 tapers from .778 – .938”
If you have an older lathe, most of the time they are #1. I have an old lathe, might be Craftsman, doesn’t have a name on it anywhere. I just know it’s old and a light brown color, but it works for what I need it for.
2991 posts in 900 days
604 days ago
Let me caution you!
Once you take one “puff” of turning you will be well on you way to becoming addicted to the craft.
You can have a lot of lfun with these older lathes without too much extra equipment.
But, you will be “jonesing” for a new “this” and a new “that” each time you finish up a job with your lathe.
Now don’t say you havent been warned and go out there and have some fun!
tenontim
604 days ago
Bob is right. I used to do turnings for my Dad when I was a kid. Of course, I was just doing chimp work reproducing broken chair parts for furniture he was restoring. Went almost 30 years before I bought the lathe that I have now. The only thing I turn is the adjusting knobs for my Morris chairs. But I will admit, I spend a considerable amount of time looking at turned bowls and vases. I’ve been checking out the burls and stumps of trees in my yard. Maybe I’ll be able to resist :o}
kevinw
603 days ago
Unfortunately I have been fighting a flu, so haven’t done much in the shop. Have done some reading while recuperating about lathe work. Probably best to read up some first anyhow rather than knocking my head off with doing something stupid. I did remount the lathe motor today and did a few things but quickly lost steam. Trying to maintain a focus on a dresser I am building as a long overdue wedding gift to my stepdaughter. But hopefully I can get the “addiction” before too long!
kevinw
600 days ago
chucked in some old junk wood tonight and gave it the first whirl. It definitely isn’t as easy as it looks, but I had a lot of fun. I knew that old cedar board I tore off the deck last summer would be good for something! I will turn it all into dust pretty much just for practice!
