Delta unisaw
Forum topic by FancyShoes posted 02-06-2018 07:40 PM 543 views 0 times favorited 3 replies Add to Favorites Watch
View FancyShoes's profile
FancyShoes
592 posts in 1603 days
02-06-2018 07:40 PM
Delta 10” unisaw right tilt 5hp 3ph
Runs great, smooth movment throughout tilt and height adjustment. Includes biesmeyer fence 28” fence. $1000
Static phase convertor available to run it for $160 additional.
I will have to post pictures later. Located in Indianapolis, In
3 replies so far
View LesB's profile
LesB
1918 posts in 3682 days
#1 posted 02-06-2018 10:06 PM
Sounds good except for the right tilt blade. I mistakenly and out of ignorance got a Unisaw with the right tilt. It cuts great but for a lot of mitered cuts I have to move the fence to the left side of the table, usually for safety reasons.
Given a choice I would replace it with a left tilt. Mine is a 3hp single phase and has plenty of power. I don’t know much about 3 phase but it sounds like just another technical problem I wouldn’t want. Was the saw use commercially? That could mean a lot of wear on bearings, etc.
-- Les B, Oregon
View Nubsnstubs's profile
Nubsnstubs
1434 posts in 1969 days
#2 posted 02-06-2018 11:34 PM
Right tilt, left tilt. It’s all subjective. If you want the saw, buy it. A 220 volt 3-5 hp motor would cost about the same as a VFD, so change out the motor to 220. You do not need to get the exact same mounting as I made mounts for 56 base that hangs in the Delta motor mount. Been using it since ‘92. Had to make another when I went to 5hp. I’ll post pictures if you ask. ............. Jerry (in Tucson)
View TheFridge's profile
TheFridge
10817 posts in 1725 days
#3 posted 02-07-2018 12:51 AM
Have 2. Has never been a problem.
