Framing square
« back to Hand Tools forum
Forum topic by Charliefreak posted 02-06-2018 03:53 PM 1587 views 0 times favorited 34 replies Add to Favorites Watch
View Charliefreak's profile
Charliefreak
17 posts in 394 days
02-06-2018 03:53 PM
This just popped into my inbox, and made me think “I definitely want one of those”. Then I followed the link and discovered that it was $230.
Precision framing square from Woodcraft / Woodpecker
Does anyone know of a good similar / equivalent product that isn’t so eye-wateringly expensive. A long, accurate square that can sit on one edge and can also square up to the edge of sheet goods would be a really useful thing for the work I do.
34 replies so far
View Loren's profile
10477 posts in 3849 days
#1 posted 02-06-2018 03:59 PM
Not the same thing, but big, square and
possible to modify easily.
https://www.andersonplywood.com/square-for-festool-mft-square/
Charliefreak
#2 posted 02-06-2018 04:03 PM
Or I suppose I could make something similar myself… but then how do I check that it’s square without a square :)
View Johnny7's profile
Johnny7
398 posts in 1291 days
#3 posted 02-06-2018 04:07 PM
Or I suppose I could make something similar myself… but then how do I check that it s square without a square :)
- Charliefreak
The same way you’d check any square—
1. Put one leg of the square against a known straight edge, then draw a line along the other leg.
2. Flip it over and draw another line near the original line.
3. If the 2 lines are anything other than parallel, the “square” is not square
View brtech's profile
brtech
1052 posts in 3124 days
#4 posted 02-06-2018 06:35 PM
you aren’t going to get .001” per foot accuracy that way :)
I have several Woodpecker products. They are great. I lust for this one, but it’s just too much!
View Holt's profile
Holt
279 posts in 2830 days
#5 posted 02-06-2018 06:49 PM
I really want the set, but the thought of telling my wife I spent $400 on them is giving me anxiety.
-- ...Specialization is for insects.
View LittleShaver's profile
LittleShaver
422 posts in 821 days
#6 posted 02-06-2018 07:07 PM
If you want to improve the accuracy of the checking method described above. Extend the lines by butting up a good straightedge to the square.
-- Sawdust Maker
View jonah's profile
jonah
1921 posts in 3500 days
#7 posted 02-06-2018 07:25 PM
Woodcraft also sells a $15 Starrett framing square that is perfectly square. I know which one I’d rather buy.
View Rich's profile (online now)
Rich
3880 posts in 790 days
#8 posted 02-06-2018 07:26 PM
Get a nice carpenter’s square and a set of stair gauges and you’re all set. Look for readability and cleanly etched markings. If you get it home and it’s a little out of square, you can tweak it with a center punch. Search around for a tutorial on how.
Charliefreak
#9 posted 02-06-2018 07:30 PM
That’s a great tip! Stair gauges… brilliant.
View Gene Howe's profile (online now)
Gene Howe
11064 posts in 3630 days
#10 posted 02-06-2018 07:43 PM
I know what used stair gauges are, but never used them before. How would you use them in check a framing square for accuracy?
Rich
#11 posted 02-06-2018 07:51 PM
- Gene Howe
They basically just add a lip to the square. That way you can lay it on the surface of a board and have them hook the edge, rather than trying to have one leg down on the front edge of the board.
It would be a good idea to do the square check with them attached to make sure you can draw good lines square to an edge. Obviously for inside and outside square checking you can leave them off.
View Holt's profile
Holt
#12 posted 02-06-2018 08:09 PM
Didn’t see it at Woodcraft and was ready to call you out, but there is one on Amazon for about that price!
Answers to one of the questions indicates it was made in China. Several reviews mention it being out of square. be cool if it turned out to be American made and typical Starrett quality.
All of that aside, it’s not RED and doesn’t come with a fitted MDF storage “case” (I’m assuming Woodpecker tricks it out like they do the other squares for which I paid entirely too much).
- jonah
Charliefreak
#13 posted 02-06-2018 08:17 PM
The fitted mdf storage case actually runs you an extra $40!
As previous poster said, I’d love to be able to:
(a) hook the square onto the edge of a board and know that it is indeed square there (rather than lining it up with my fingers like I currently do
(b) be able to stand the square up on one edge and have it stay put, the way an engineer’s square does.
I’m going to give the stair gauges a try as they might achieve both of those things.
View Dwain's profile
Dwain
576 posts in 4060 days
#14 posted 02-06-2018 08:24 PM
I DID buy that Starrett framing square. Very happy with it. I’m going to go out and burn $5 on a set of stair gauges and get more use from it. By the way, Starrett sells stair gauges… for $42.00! I love Starrett, but I ain’t investing in that.
-- When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there is no end to what you CAN'T do
jonah
#15 posted 02-06-2018 08:26 PM
This is what I’m talking about. They call it a “rafter square” for some unknown reason. Made in the USA and mine is absolutely square as can be (or as close as I can see with 20/15 vision).
https://www.woodcraft.com/products/starrett-tempered-steel-rafter-square
showing 1 through 15 of 34 replies
