cutting a circle in a laminate counter top
Forum topic by theshed posted 02-06-2018 11:27 AM 1290 views 0 times favorited 10 replies Add to Favorites Watch
View theshed's profile
theshed
15 posts in 410 days
02-06-2018 11:27 AM
I am cutting an old piece of laminate counter top that will eventually be the frame for a clock. I am using a router. I have never cut laminate. All cut edges will be exposed. I have 3 questions.
1) What type of router bit do I use?
2) Will/can the laminate chip?
3) Do I need to tape the cut lines?
10 replies so far
View cabmaker's profile
cabmaker
1740 posts in 2928 days
#1 posted 02-06-2018 12:19 PM
bandsaw would be best…...with laminate up
just pin the radius from the bottom of the substrate ( not completely through )
place the pin on your mark on the bandsaw table…( ply overlay on saw table top )
You will need to cut a relief first to allow you to start at the line or simply freehand far enough to allow you to drop into your radius mark
theshed
#2 posted 02-06-2018 12:22 PM
the clock face will be inset into the laminate frame. That needs to be cut with a router.
cabmaker
#3 posted 02-06-2018 12:35 PM
Oh….I see…...sometimes it helps if you put some criteria like that in your post to aid in getting more accurate relplys
Thats an easy one
Enjoy !
theshed
#4 posted 02-06-2018 12:48 PM
I know how to do it, my original question was will the laminate chip using a router?
View jbay's profile (online now)
jbay
2593 posts in 1018 days
#5 posted 02-06-2018 02:27 PM
1/4” straight bit
No, but yes it could if not executed skillfully
No
I would make 3 passes, lowering the bit each pass.
View rwe2156's profile
rwe2156
3069 posts in 1600 days
#6 posted 02-06-2018 03:44 PM
Laminate is pretty resistant to chipping as long as the bit is sharp you will be fine.
Rather than cuting the circle out with a router bit, I would cut it close to final dimension with a jigsaw and use a template and pattern bit. The more passes you make the more potential for chipping one little error or hiccup and you’re done.
theshed
#7 posted 02-06-2018 04:20 PM
Thanks for the comments. Always learning something. I decided to go for it with the router using a double flute straight bit. Worked well.
View LesB's profile
LesB
1801 posts in 3562 days
#8 posted 02-06-2018 10:15 PM
I agree with rwe2156 but I think you might also use a spiral bit. If you are cutting from the laminate side you would want a down cutting spiral bit to avoid lifting the laminate while cutting. If cutting from the other side you would want a up cut bit.
-- Les B, Oregon
View JackDuren's profile
JackDuren
388 posts in 1078 days
#9 posted 02-06-2018 11:13 PM
Rather than cuting the circle out with a router bit, I would cut it close to final dimension with a jigsaw and use a template and pattern bit. The more passes you make the more potential for chipping one little error or hiccup and you re done.
- rwe2156
Incorrect… Just use the router…A plunge router
View ArtMann's profile
ArtMann
1044 posts in 935 days
#10 posted 02-07-2018 03:01 PM
The original poster didn’t provide enough information initially to understand what he was talking about. This happens all the time. It is a hazard of purely textual communication. As someone said, “the biggest problem with communication is the assumption that it has actually occurred”.
