Most durable finish for Bottle Toppers and pens
Forum topic by Keen1 posted 255 days ago 144 views 0 times favorited 6 replies Add to Favorites
View Keen1's profile
Keen1
68 posts in 374 days
255 days ago
Topic tags/keywords: question
Have the chance to sell both through a local shop. I want to make sure they are good quality. I’ve noticed the friction polish I”ve used on pens in the past tends to wear quickly. Most concerned about the bottle toppers since they could come into contact with some vino…..I’ve bought some of the stainless steel “FDA approved” topper hardware and now wondering what finish is best to sell to general public. CA? If so anything like Ren wax after or just leave it at CA? 2-3 coats? Thanks for the input.
-- Dad to 5, Son of The One
Douglas Bordner
2707 posts in 592 days
255 days ago
Although the drying time is much greater than CA, I would likely give Salad Bowl Finish a try. Behlens and General Finishes both make this. It is essentially an oil based varnish, so it’s tough and is FDA approved for food contact when fully cured. And it’s a wipe-on product. I use Mylands friction polish or Ubeaut’s Shellawax creme on my pens, but I would be concerned that the alcohol in vino might not work so well with shellac based finishes. Just my 2ยข.
View rikkor's profile
rikkor
8362 posts in 403 days
255 days ago
I have had issues with pens dulling fairly quickly with use. Douglas, where do you get the Mylands or the Ubeats?
-- Maplewood, MN
6517 posts in 379 days
255 days ago
Like douglas I use the Shellawax but use the EEE cutting compound to get a smoother finish before burnishing with the Shellawax. you could you wood turners wax (comes in lumps), the more coats the more protection.
Douglas Bordner
255 days ago
Rikkor-
Craft Supplies, USA
Has the Mylands products. I usually use the lacquer based Cellulose Sanding Sealer before using the friction polish
Penn State Industries has the Shellawax products
Ubeaut website has them of course, but this might be more costly to get shipped directly. I was intrigued by one of Don’s post about Hard Shellac, but have yet to stumble across any purveyors of this product here across the pond.
Tony/Grumpy,
Have you ever used that Hard Shellac?
rikkor
254 days ago
Thanks Douglas.
-- Maplewood, MN
View jeffthewoodwacker's profile
jeffthewoodwacker
202 posts in 332 days
254 days ago
I like to use thin CA for the first two coats of finish on pens followed up by Mylands friction polish (also available at Woodcraft). I have also used BLO and varnish cut mixture on pens that will be used a lot. The Beall system is also a good choice but is expensive.
-- Genius is immediate, but talent takes time.
Bookmark And Share This Page
