Harbor Freight DC Motor Issue?
Forum topic by BoilerUp21 posted 02-06-2018 01:43 AM 1880 views 0 times favorited 28 replies Add to Favorites Watch
View BoilerUp21's profile
BoilerUp21
111 posts in 1003 days
02-06-2018 01:43 AM
I converted my HF dust collector to a cyclone with Wynn filter about 6 months ago. I noticed that i started losing ~10% suction lately and then ~20% more recently. I figured it had something to do with my 30 gallon chips bin under the cyclone filling up twice in the last couple weeks while jointing/planing a bunch of oak…
The DC is having trouble starting up (almost sounds like a car struggling to start) and after about 3 seconds, it trips the breaker. I figured it was something to do with the Wynn filter being clogged and the DC not being able to efficiently push air through the clogged pleats. After taking the filter off and cleaning it with air, i had the same issue.
Finally, i took the impeller cover off to verify there were not clogs or anything causing it not to rotate.
After all of this, i still cannot pinpoint the problem, but have to assume it has something to do with the motor or wiring. Has anyone else heard/had a similar issue with the HF DC? There is not obvious burning smell or smoke and other tools on the same 20amp circuit work fine…
Any help is greatly appreciated.
28 replies so far
View caboxmaker's profile
caboxmaker
281 posts in 623 days
#1 posted 02-06-2018 01:57 AM
Maybe HF is the problem…
BoilerUp21
#2 posted 02-06-2018 02:04 AM
Well that is a good point, but not the help i was looking for…
- caboxmaker
View TheFridge's profile
TheFridge
10815 posts in 1721 days
#3 posted 02-06-2018 02:05 AM
Sounds like capacitor.
View DIYaholic's profile
DIYaholic
19738 posts in 2910 days
#4 posted 02-06-2018 02:24 AM
- TheFridge
+1
BoilerUp21
#5 posted 02-06-2018 02:32 AM
thanks guys. I have done some reading on other similar issues and i believe it is the capacitor as well. Any idea on how to get a replacement or where to get one?
View AlaskaGuy's profile (online now)
AlaskaGuy
4983 posts in 2545 days
#6 posted 02-06-2018 02:40 AM
- TheFridge
I think you’re right. Being HF I doubt the used the “good” Alder.
View IantheTinker's profile
IantheTinker
273 posts in 362 days
#7 posted 02-06-2018 02:46 AM
Have you tried grainger.com? It is a motor parts website, might be worth a shot.
Also, the problem is not that it is from Harbor Freight, their dust collector is one of their gems. Overall the store isn’t all that bad, just gotta figure out what’s worth it and what isn’t, just like any other store.
-- opiningminnesotan.com
BoilerUp21
#8 posted 02-06-2018 02:59 AM
Thanks. I just ordered DAYTON Round Motor Start Capacitor,400-480 Microfarad Rating,110-125VAC Voltage from Grainger and will see if this solves the problem. Appreciate it.
- IantheTinker
IantheTinker
#9 posted 02-06-2018 03:38 AM
- BoilerUp21
No problem, glad I could help. I hope it works out for you, a shop without DC can be rough.
AlaskaGuy
#10 posted 02-06-2018 03:46 AM
- BoilerUp21
That was quick, hopefully that’s the fix.
View William Shelley's profile
William Shelley
608 posts in 1705 days
#11 posted 02-06-2018 03:46 AM
- IantheTinker
- BoilerUp21
Careful, the capacitor needs to be rated for 250 or 370VAC usually. 480uf seems awfully large for a 2HP motor.
-- Woodworking from an engineer's perspective
View crank49's profile
crank49
4032 posts in 3206 days
#12 posted 02-06-2018 06:03 AM
While we’re at it, this is a good learning opportunity.
A filter being clogged would NOT increase the load on the motor.
Exactly the opposite.
View skipj's profile
skipj
97 posts in 2508 days
#13 posted 02-06-2018 12:16 PM
When this happened to my HF motor I replaced the capactor, It’s not the problem.
On mine the bearing on the fan end of the motor was almost frozen.Replaced it and now works great.
I think the bearing was about $12..Time consuming but a easey fix.
I think i still have the old bearing and the package the new bearing came in.If you need the bearing number
and wher i got it let me know. Replace the CAP first, thats easey.
Not the motor fan end,The impeller end.
BoilerUp21
#14 posted 02-06-2018 12:59 PM
The one that comes out of the HF is listed as 125V.AC
- IantheTinker
- BoilerUp21
- William Shelley
BoilerUp21
#15 posted 02-06-2018 01:00 PM
Any idea where/what size you ordered?
When this happened to my HF motor I replaced the capactor, It s not the problem.
- skipj
showing 1 through 15 of 28 replies
