Making elk antler lamp
Forum topic by ROH posted 02-05-2018 11:21 AM 411 views 0 times favorited 5 replies Add to Favorites Watch
View ROH's profile
ROH
2 posts in 312 days
02-05-2018 11:21 AM
Any clues on how to drill the hole for the cord lengthwise thru the antler?
-- rohammel@gmail.com
5 replies so far
View Gilley23's profile
Gilley23
489 posts in 583 days
#1 posted 02-05-2018 02:22 PM
You may have to cut the antler, drill the holes to meet and then glue it back together. Use the thinnest kerf you can find.
View LesB's profile
LesB
1863 posts in 3644 days
#2 posted 02-05-2018 05:56 PM
You can buy long shaft drill bits if the length of you bits is the problem.
At sharp bends you might have to start a new crossing hole from the outside and plug it when you have the wire installed, so save the drill material so you can mix it with epoxy or thick superglue fo the patch. Of if you have spare material you could cut a plug for the hole.
I would think if you cut the antler some sort of reinforcement at the glue joint will be needed. Maybe a metal tube or if the point of the cut is wide enough you can drill a couple of smaller holes to put reinforcing metal pins in.
-- Les B, Oregon
View tomsteve's profile
tomsteve
878 posts in 1420 days
#3 posted 02-05-2018 07:21 PM
you may want to try and contact Jan, the antler lady. shes been doing this type of work for many years
http://www.jantheantlerlady.com
View ROH's profile
ROH
2 posts in 312 days
#4 posted 02-05-2018 07:24 PM
Thanks for all your input.
View Bill White's profile
Bill White
5125 posts in 4161 days
#5 posted 02-05-2018 08:26 PM
Lamp drill? Won’t do curves, but ya might be able to fix with with different drill locations/directions.
Bill
-- bill@magraphics.us
