Fence Position When Cutting Large Panels on Table Saw with 50 inch rails
Forum topic by C_PLUS_Woodworker posted 04-04-2011 08:38 PM 1895 views 0 times favorited 8 replies Add to Favorites Watch
View C_PLUS_Woodworker's profile
C_PLUS_Woodworker
601 posts in 2811 days
04-04-2011 08:38 PM
Topic tags/keywords: tablesaw
Scenario:
3 hp table saw with 50 inch rails to the right with extension table
Waxed tops with no sawdust
Good out-feed support
Assume fence/miter slot/blade are all parallel…..............no dialed-in toe in/toe out on fence
You have a panel of 3/4 ply that is 48×48
You want to cut 2 inches off to make the panel 46×48
Do you move the fence to 46 inches and use the fence on the right of the blade as a guide? (with the blade 4 ft away)
Or do you move the fence 2 inches to the left of the blade and use the fence on the left as the guide? (with the blade much closer to the fence)
Why?
8 replies so far
16272 posts in 4122 days
#1 posted 04-04-2011 08:48 PM
I would do it the first way.
I believe it is safer and easier to control the cut when the piece between the blade and the fence is larger than the piece on the opposite side of the blade.
View Sawkerf's profile
Sawkerf
1730 posts in 2972 days
#2 posted 04-04-2011 08:48 PM
I almost always work with the fence on the right because it’s more comfortable for me that way. I’ve worked from the left, but only for odd situations.
View bubinga's profile
bubinga
861 posts in 2571 days
#3 posted 04-04-2011 08:52 PM
No doubt about it move the fence to 46 inches and use the fence on the right of the blade as a guide
-- E J ------- Always Keep a Firm Grip on Your Tool
View drewnahant's profile
drewnahant
222 posts in 2993 days
#4 posted 04-04-2011 09:01 PM
You always push between the fence and blade, and you always reference off of your fence, so ideally, the heavier piece of stock should be in that area, and for a straighter cut, the finish piece should always be there. if you have a large piece hanging off to the left, it can bend away as you near the end of your cut, but the section on the right can always stay true to the fence, that should be your finish piece.
If you have the 50” rails, go to the 46” fence setting. it is much more stable and safer to push that large section of the sheet against the rail
View JJohnston's profile
JJohnston
1622 posts in 3195 days
#5 posted 04-04-2011 09:19 PM
Neither. A cut like this, with the workpiece twice as wide as it is long, calls for a panel cutting sled. Just a simple one would do, with the fence at the front and no back fence at all, and a single miter slot runner. You can whip up one of these in a few minutes.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
bubinga
#6 posted 04-04-2011 09:34 PM
algale
Good one
C_PLUS_Woodworker
#7 posted 04-04-2011 09:46 PM
Thanks for the replies
I always do it the first way with the fence out on the right, but sometimes when I am just sizing a large piece with a real small drop I feel like I would like to be closer to the actual cut to keep an eye on it better.
I never have done a large piece with the fence on the left of the blade because I worried about binding the small piece.
But, was just wondering if I was missing something that I should know.
Thanks again.
JJohnston
#8 posted 04-04-2011 09:58 PM
You cut it to rough size with a circular saw and guide, then make the final, squaring cut after the fence is squared to the runner. Do this with the runner in the miter slot and you’ll have the exact location of the saw cut built into the jig.
