Birch Plywood Veneer Quality
Forum topic by BillAllemon posted 02-05-2018 11:21 AM 410 views 0 times favorited 9 replies Add to Favorites Watch
View BillAllemon's profile
BillAllemon
2 posts in 134 days
02-05-2018 11:21 AM
Topic tags/keywords: plywood birch plywood plywood quality tear out
I have a Newbie question. I needed to drill a 3/8” hole into a birch plywood panel, didn’t use a backer at the hole and got some tear out. I purchased the plywood at a big box home center. Does higher quality plywood from a real lumber yard have thicker veneer? Thanks.
9 replies so far
View cabmaker's profile
cabmaker
1735 posts in 2832 days
#1 posted 02-05-2018 11:36 AM
maybe…....maybe not
Whether or whether not that solves the problem for you is anyones guess
Depends greatly on what your drilling with and who’s hand is on the drill
Typically speaking…. plywood from any big box store as you call em is low quality
View rwe2156's profile
rwe2156
2958 posts in 1503 days
#2 posted 02-05-2018 03:04 PM
It will happen even on high quality plywood.
Gotta remember that backer!
View Rich's profile
Rich
2963 posts in 612 days
#3 posted 02-05-2018 03:16 PM
- rwe2156
Or solid hardwood for that matter.
View LesB's profile
LesB
1748 posts in 3466 days
#4 posted 02-05-2018 05:38 PM
Use brad point drill bits and a backer board. Drill over a fresh spot on the backer board for each hole.
If you want to be very careful about the tear out I would first drill a 1/16” hole in the center as a guide hole so you can then use a Forstner bit from both sides to get a clean cut. The 1/16” hole is not to guide the Forstner bit but to mark both sides of the wood so the holes line up. Make sure you are drilling at 90 degrees.
By the way almost all “veneered” type ply wood these days has a veneer so thin you can almost scratch it off with a finger nail. So be careful if you power sand it too or you will go right through the surface layer.
-- Les B, Oregon
View MrRon's profile
MrRon
4793 posts in 3266 days
#5 posted 02-05-2018 06:30 PM
You should be using a brad point bit, a backer board and applying adequate downward pressure on the work to prevent it from lifting. I don’t think a forstener bit would work better because I think it would tend to “grab” the thin veneer going in and coming out. You need the outside cutting edge of a brad point to cleanly score the edge of the hole. Some forstener bits have that a toothed edge that may work.
View Rich's profile
Rich
#6 posted 02-05-2018 06:33 PM
I don t think a forstener bit would work better because I think it would tend to “grab” the thin veneer going in and coming out.
- MrRon
Using Les’s method, the bit doesn’t come out the other side, so you get a perfectly clean hole on both sides of the board.
MrRon
#7 posted 02-05-2018 08:37 PM
Using Les s method, the bit doesn t come out the other side, so you get a perfectly clean hole on both sides of the board.
- Rich
True. I’m assuming he is drilling a hole freehand, not with a drill press.
View LesB's profile
LesB
#8 posted 02-05-2018 08:53 PM
Good quality Forstner bits have a small spurs that pre cuts the edge of the hole just like brad point.
-- Les B, Oregon
BillAllemon
2 posts in 134 days
#9 posted 02-06-2018 05:04 AM
Thanks for the quick feedback and all the comments! I appreciate it.
