Thanks
Forum topic by tigger959 posted 624 days ago 100 views 0 times favorited 3 replies Add to Favorites Watch
View tigger959's profile
tigger959
9 posts in 626 days
624 days ago
Just wanted to say Hi and Thanks to all that have welcomed me aboard. I am nearing retirement (2 years) and am building a 2 bedroom home to celebrate. Health issues limit my total involvement into the project but I do plan on completing as much as I possibly can.
The home is 1200 SF and is on piers (live on the river bottom). Have the sub-flooring completed and used a product called Advantech manufactured by Huber Woods (www.huberwood.com). The material is 3/4” T&G OSB. It is water resistent and has a 50-year warranty. I have not been able to frame due to the constant rains but as soon as the OSB dries, it looks brand new again. Fantastic is all I can say. It’s quite expensive ($28.00 for a 4’x8’ sheet) but is well worth it when is all said and done.
I will be having a carport and will incorporate a 10’x10’ shop. My question is:
If any of you had this to do, how would you design it to optimize your space? I haven’t done any woodworking for a number of years for various reasons but am going to begin anew. I have air tools, drill, miter saw, router, table saw as well as a variety of hand tools. Over time I will be adding equipment. However, because of space limitations, I do need to plan correctly. I have just purchased and setup a portable table for the miter saw. It’s a Denali stand that required my bolting the miter saw to it. My next project will be to build a router table. I’m looking at two different ones. The first would be an add-on to the table saw and the other is a simple table that I recently downloaded the plans to complete.
Because I shake at times, I won’t be doing any fine craftsman type work. I will be doing simple projects to help me relax. Any help will be deeply appreciated.
View GaryK's profile
GaryK
9533 posts in 885 days
624 days ago
For a shop of that size consider putting everything on wheels so you can move them around as you work.
View HallTree's profile
HallTree
2041 posts in 664 days
624 days ago
Yeaaaa retirement. Soon after you retire and spend more time in your shop you will say “When did I ever have time to go to work”. Take your time to set up your shop so you get it just the way you want it. Take a look at some of the shops shown here. Find some you like and ask questions. The group here is always willing to help. Let’s see some photo’s of your home, shop, and projects. We like photo’s. Have fun and work safe.
-- Ron in Osseo, Minnesota
20732 posts in 718 days
624 days ago
I had a friend whose shop was similar in size. He only had a bandsaw, tablesaw, and a benchtop jointer and planer but the saws were on wheels and he kept them against the wall until he needed them. Then it was outside for cutting. Working in the shop was a challenge but, as in kitchen design, he kept the jointer, planer and a small workbench in a triangle. All you had to do was turn around from one tool to the other but he managed to work in there.
