Another what kind of wood is it?
Forum topic by Steve posted 02-04-2018 07:58 PM 684 views 0 times favorited 19 replies Add to Favorites Watch
View Steve's profile
Steve
826 posts in 823 days
02-04-2018 07:58 PM
Found it in the woods here in Northern Va. I’m fairly confident it isn’t alder.
I sliced a few boards out of a piece and was just wondering what kind of wood it was.
19 replies so far
View TheFridge's profile
TheFridge
10818 posts in 1727 days
#1 posted 02-04-2018 08:11 PM
Looks like hickory alder
View Tony_S's profile
Tony_S
953 posts in 3324 days
#2 posted 02-04-2018 08:12 PM
The picture is too far away, but It looks like Hickory.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
Steve
#3 posted 02-04-2018 08:13 PM
now that you guys mention it, it did have a different smell when i was cutting it. so hickory sounds like a winner.
thanks guys
TheFridge
#4 posted 02-04-2018 08:27 PM
It may not be alder. But it probably is.
Steve
#5 posted 02-04-2018 08:38 PM
I’m going to see if I can make a small miter box out of it. That is if I ever figure out the moisture content of it.
View tomsteve's profile
tomsteve
897 posts in 1460 days
#6 posted 02-04-2018 08:56 PM
I m going to see if I can make a small miter box out of it.
- bndawgs
for cutting alder only.
View msinc's profile
msinc
569 posts in 744 days
#7 posted 02-04-2018 09:25 PM
I am not too far away from there, we have a lot of hickory here and that bark isn’t quite what I am used to seeing. If it is hickory you should be able to go back to that spot and see the hulls laying around on the ground. maybe even find some leaves that it dropped. I realize leaves on the ground and nut shells could come from other trees in the area, but if there are none of either than it might just be something else. The bark almost looks a little like persimmon.
View AlaskaGuy's profile
AlaskaGuy
5002 posts in 2550 days
#8 posted 02-04-2018 09:43 PM
Steve
#9 posted 02-04-2018 09:54 PM
Here’s a few more close up shots.
AlaskaGuy
#10 posted 02-04-2018 10:01 PM
AlaskaGuy
#11 posted 02-04-2018 10:05 PM
And even more
https://northernwoodlands.org/knots_and_bolts/make-your-own-axe-handle
View WDHLT15's profile
WDHLT15
1797 posts in 2717 days
#12 posted 02-05-2018 12:30 PM
The large medullary rays visible to the naked eye on the end grain indicate that it is oak, to be more specific, one of the red oaks.
Steve
#13 posted 02-05-2018 05:32 PM
- WDHLT15
Hmm, does Red Oak give off any particular smells when cutting it?
tomsteve
#14 posted 02-05-2018 07:24 PM
- bndawgs
red oak does have a distint smell to it-some say it smells like cat pee. apparently i like the smell of cat pee.
Steve
#15 posted 02-05-2018 09:58 PM
- bndawgs
- tomsteve
that’s ok. i don’t mind the smell of skunks when i drive by one that’s been hit.
