Should I replace the breaker on Delta 36-540 table-saw?
Forum topic by wildbill001 posted 04-04-2011 03:38 PM 2336 views 0 times favorited 3 replies Add to Favorites Watch
View wildbill001's profile
wildbill001
111 posts in 2760 days
04-04-2011 03:38 PM
Topic tags/keywords: tablesaw
Quite a while back I picked up a Delta table-saw, 36-540 for next to nothing (ok, stop laughing, it does what I need it to do most of the time.) Recently, the breaker that is part of the saw keeps tripping for what I think is no apparent reason. I’ve blown the dust out of the bottom on the saw, replaced the blade with a new Freud Diablo rip and that helped a bit. The breaker is only about $20.00 but before I spend that, is there any way to test the old one to make sure that is the problem?
For those curious, I only rip on this saw, mostly soft to medium-hard woods.
Thanks in advance
Bill
-- "You can tell the pioneers by the arrows in their back" -- Unknown
3 replies so far
View Stormin's profile
Stormin
193 posts in 2908 days
#1 posted 04-04-2011 03:52 PM
If you have an amp meter or a friend that does you could check the draw on the motor when you are ripping a piece of wood. If not jumper out the overload and give it a try ( keep a close eye and ear on the saw ) If it is something major your breaker will trip. If the saw runs fine and the breaker stays on replace the overload.
-- I started off with nothing I have most of it left
View bubinga's profile
bubinga
861 posts in 2786 days
#2 posted 04-04-2011 03:54 PM
It might be motor that needs repair ,and not the breaker
Where is the breaker located?
In the motor?
-- E J ------- Always Keep a Firm Grip on Your Tool
wildbill001
#3 posted 04-04-2011 08:05 PM
breaker is located next to the on/off switch, NOT on or in the motor.
The motor always sounds fine as the breaker trips.
I”ll ask around and see if anyone I know has an amp meter. I’m tempted to just spend the $15-20 and replace the breaker. That would almost double what I have in the saw….
