Looking for a particular fixture ...
Forum topic by christopolos posted 02-04-2018 03:26 PM 323 views 0 times favorited 6 replies Add to Favorites Watch
View christopolos's profile
3 posts in 41 days
02-04-2018 03:26 PM
Topic tags/keywords: insert fixing bushing clearance fixture
Hi, can someone who is smarter than the average bear help me out and point me in the right direction ?
Looking for something very similar to this image – this is a reducer bushing.
What I’ve been trying to find is this but without the thread on the inside, just threaded on the outside. So it can be wound into wood, with either a Philips head or hexagon key.
I will be running a M6 bolt through this fixture and looking for something to act as a clearence hole and not threaded.
Cheers, Chris
View waho6o9's profile
8126 posts in 2507 days
#1 posted 02-04-2018 03:39 PM
Oops, not threaded on the outside. Sorry about that.
Might have to make your own.
View mahdee's profile
3849 posts in 1697 days
#2 posted 02-04-2018 03:42 PM
Threaded insert?
#3 posted 02-04-2018 03:48 PM
You can get a pipe that size and use a steel hex die and thread the outside.
View Woodknack's profile
11286 posts in 2310 days
#4 posted 02-04-2018 05:57 PM
If you can find a reducer bushing with the head you want, thread into scrap wood for leverage and drill out the inside.
-- Rick M,
6472 posts in 2129 days
#5 posted 02-04-2018 06:16 PM
Check here – might not be exactly what you are looking for, but should help with your search:
Threaded Bushings
(Norwood screw machine parts)
View JAAune's profile
1780 posts in 2246 days
#6 posted 02-05-2018 01:15 AM
Drill bushings might be useable. Some are made with machine threads which may not be ideal, but should still work.
-- See my work at and
