Releasing Old Glue Joints
« back to Joinery forum
Forum topic by TheWoodenOyster posted 02-03-2018 08:04 PM 707 views 0 times favorited 10 replies Add to Favorites Watch
TheWoodenOyster
1317 posts in 2175 days
02-03-2018 08:04 PM
Topic tags/keywords: glue joint
Hey guys-
I have an old mid century modern chair that I am trying to take apart and refinish. My guess is it is probably from the 60’s or so. The joints are all mortise and tenon or dowels with really good tight fits. Chair is maple. I am not sure what kind of glue was used, but a few of the joints have come loose over time, so that does give me some hope that I may be able to get the rest to release. Do any of you have tips or tricks on getting these old glue joints to come loose?
Thanks,
Dave
-- The Wood Is Your Oyster
10 replies so far
View HerbC's profile
HerbC
1792 posts in 3099 days
#1 posted 02-03-2018 08:30 PM
If it’s hide glue it can be released by using heat. Moisture helps so a steam source can work well.
Other glues are generally not releasable.
Good Luck!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View Loren's profile
10477 posts in 3887 days
#2 posted 02-03-2018 10:49 PM
View Woodknack's profile
Woodknack
12468 posts in 2620 days
#3 posted 02-03-2018 11:04 PM
The enemy of glue is heat.
View Richard Lee's profile
Richard Lee
213 posts in 1015 days
#4 posted 02-03-2018 11:17 PM
- Rick_M
Or Kids.
View Lazyman's profile
Lazyman
2708 posts in 1627 days
#5 posted 02-03-2018 11:30 PM
Are you trying to just remove the loose joints or the disassemble the whole chair? If the other joints are sound, I wouldn’t mess with them unless you have to.
Some pictures of the problems may help get more specific advice.
PVA was pretty widely used by any large furniture companies from about the 60’s (at least) on so chances are that is the kind of glue that was used. That will make it fairly difficult to get appart without doing more damage unless the joint is already loose. Note if it is PVA, you have to completely remove the old glue, without making the joint even looser to reglue it. PVA will not bond to PVA.
Woodknack
#6 posted 02-04-2018 03:14 AM
Or Kids.
- Richard Lee
LOL
View Rich's profile
Rich
4012 posts in 829 days
#7 posted 02-04-2018 04:42 AM
I’ve never seen a glue joint that could resist a hammer.
View JohnDi's profile
JohnDi
60 posts in 1673 days
#8 posted 02-04-2018 10:59 AM
Heat gun.
Check out Thomas Johnson antique restoration on YouTube
View Tennessee's profile
Tennessee
2893 posts in 2754 days
#9 posted 02-04-2018 01:51 PM
Back in the 70’s and 80’s, when I had my refinishing shop, I would get in loose chairs every week.
I used to bang them apart with rubber mallets, with success but once in a while, would snap one off and have to remake the stringer or dowel it.
Then, we got smart and if the chair could be stretched so the hole was clear and the peg was available, just sand it all down to get rid of the old glue, (usually some sort of PVA or old hide glue, sometimes some awful who knows what the owner tried to use), then hand saw a groove in the end of the stringer/leg, etc., put in a wedge in the male end groove, and reglue and press it back together. Saved probably hundreds of chairs that way, and it was much faster and easy.
TheWoodenOyster
#10 posted 02-06-2018 02:45 AM
Thanks for the input guys. I am going to give the rubber mallet method a shot and see what I can do.
