Small gouge on cabinet face frame need to repair
Forum topic by cajunworkshop posted 02-03-2018 12:56 PM 385 views 0 times favorited 10 replies Add to Favorites Watch
View cajunworkshop's profile
cajunworkshop
64 posts in 1023 days
02-03-2018 12:56 PM
I have a cabinet I am building. The face frame had a 1 inch chunk that is cracked and about to come off. Wanted suggestions on how to fix it.
Should I pull it off and repair it with some compound?
Tried to glue but couldn’t get glue under it without cracking it further
This a cabinet going out in my garage as a work bench. I want to learn how to do this otherwise I wouldn’t worry since I have 1/2” over lay doors that would mostly over when door is closed.
Any ideas?
-- Cajun Workshop Greenville, SC
10 replies so far
View mrg's profile
mrg
827 posts in 3027 days
#1 posted 02-03-2018 01:26 PM
How good are you with a chisel? I would either remove the chunk by cutting the section out. Grafting back in. If you are going to paint the base, bondo or water putty sand smooth and paint.
-- mrg
View bondogaposis's profile
bondogaposis
4769 posts in 2379 days
#2 posted 02-03-2018 01:43 PM
Pry it open and get some glue in there and clamp it closed. You may have to carve a splinter of wood to make a glue applicator that will fit in the crack.
-- Bondo Gaposis
View shipwright's profile
shipwright
7992 posts in 2825 days
#3 posted 02-03-2018 01:48 PM
Pry it up (carefully) and apply a little glue with a thin bit of wood like veneer or a shaving. If it breaks right off, so much the better because there is no better fit than a clean break. You are right to try to fix this even though it doesn’t matter much. It can be a good learning experience.
Try this before you go cutting anything away. This should make an invisible repair and will be something you can use on future pieces where they won’t be painted and where they will show.
shipwright
#4 posted 02-03-2018 01:50 PM
Simultaneous typing Bondo? :-)
View dhazelton's profile
dhazelton
2771 posts in 2324 days
#5 posted 02-03-2018 03:48 PM
If it’s where that knot appears to be the wood may be under tension there and gluing and clamping may not hold and breaking it clean might not result in tightly mated surfaces. Try it, but be prepared to use filler.
View MT_Stringer's profile (online now)
MT_Stringer
3172 posts in 3259 days
#6 posted 02-03-2018 05:14 PM
I second the idea of Bondo if the damaged piece breaks off. Repair it just like a dent in a car. It sands smooth. Then paint it.
Had to repair a template I boogered up.
cajunworkshop
#7 posted 02-03-2018 06:30 PM
Great ideas. Going to try the bondo. Is there a certain type for wood and does Woodcraft carry it.
The face frame is poplar so I am painting it. No knots in that spot. User error when I was driving a screw!
dhazelton
#8 posted 02-04-2018 01:58 AM
Regular autobody filler from the home center will do it.
View LesB's profile
LesB
1748 posts in 3471 days
#9 posted 02-04-2018 07:58 PM
Being a fan of medium or thick super glue CA for things like this I would suggest trying it. The medium and thick varieties set up slowly (5 to 15 minutes) which allows it to seep into cracks like that. Just keep adding more until the crack absorbs no more, clamp if necessary and then let it cure (or spray with an accelerator). On finer cracks use an application of the thin version of the glue followed immediately with the medium. For what ever reason the thin stuff makes the medium flow into the better. That method works especially well if the crack or void needs some filler like sawdust…..pack the sawdust in dry, wet with the thin glue and then immediately the medium.
-- Les B, Oregon
View Steve's profile
Steve
442 posts in 610 days
#10 posted 02-04-2018 08:05 PM
you can get the bondo at Home depot or lowes
