Forum topic by a1Jim posted 04-03-2011 07:55 PM 3740 views 3 times favorited 46 replies Add to Favorites Watch
117033 posts in 3514 days
04-03-2011 07:55 PM
Topic tags/keywords: question
Hey gang
I’m getting ready to teaching a couple half day classes on the router for my local community collage. The first half day class is on the basics how to use routers and it’s different parts and types of routers, pretty basic stuff. The other half of the day is for more advanced folks that have used routers before and introducing tips & jigs I have and I’ve made a bunch new jigs that I didn’t have,some I don’t need because I have some more sophisticated tools to some operations. I’ve searched the web and Ljs and made a number of jigs that a lot of folks here have made but thought I’d ask you all if you have faveriates or other tips I’ve for gotten or I don’t know.
I’ve made TDVs loose tenon mortising and tenon jig, I have a couple exact size dado jigs, a couple circle cutting jigs, an edge band trimming jig,a router stand, a couple small parts jigs,a base plate with two pins for centering, I have a router shelf pin jig, a router box joint jig, a coping sled.fluting base,shop made “D” handle,a dowel making jig.half blind and through Dovetail jigs, router tables.hinge mortise jigs.
I’m sure I’m forgetting something?
-- wood crafting & classes
46 replies so far
View Gregn's profile
1642 posts in 2920 days
#1 posted 04-03-2011 08:25 PM
How about a mortising jig?
#2 posted 04-03-2011 08:28 PM
Thanks Gregn
View Gene Howe's profile
Gene Howe
10268 posts in 3365 days
#3 posted 04-03-2011 08:49 PM
Jointing on the table router?
Pin routing?
Inlay jigs?
#4 posted 04-03-2011 08:50 PM
Thanks Gene those are good ones
View ksSlim's profile
1273 posts in 2826 days
#5 posted 04-03-2011 09:04 PM
A few minutes on pattern/template routing, either handheld or table mounted is usually appreciated.
-- Sawdust and shavings are therapeutic
#6 posted 04-03-2011 09:18 PM
Thanks ksslim good idea
13598 posts in 3278 days
#7 posted 04-03-2011 09:31 PM
a trimming jig
that the router rides on
and against a straight stop
that can be placed on the work
to cut straight and square
or be squed for taper cuts
to use with a spiral bit
and one for a dado slot for shelves
#8 posted 04-03-2011 09:37 PM
Hey David happy 2 year anniversary .
Not sure what that looks like ? Is it shaped like a framing square or is it the type that has and adjustable end that you set the stop?
View drewnahant's profile
222 posts in 3025 days
#9 posted 04-03-2011 09:41 PM
you probably have already considered this, but I think the most important jig for a router table is a coping sled.
#10 posted 04-03-2011 09:44 PM
Thanks drewnahant I did make one. It’s a good jig to have.
View TJU's profile
72 posts in 2593 days
#11 posted 04-03-2011 09:52 PM
How about using a router and straight bit to joint an edge. I don’t do that any more but I use to before I had my jointer.
-- Although the voices aren't real they have some pretty good ideas.
#12 posted 04-03-2011 09:55 PM
Thanks TJU I think thats doable another good idea
35108 posts in 4337 days
#13 posted 04-03-2011 09:58 PM
A jig to keep the router flat when cutting edge moldings.
I’m using it here on my Corian counter top.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Southern Delaware soon moving to Virginia †
#14 posted 04-03-2011 10:02 PM
Thanks Karson that makes things a lot easier to control ,good one.
View Joe Lyddon's profile
Joe Lyddon
10012 posts in 3989 days
#15 posted 04-03-2011 10:35 PM
I like the Box Jointing jigs from Oak Park...
They are very versatile jigs.
The jigs can be had ON Sale in the area of $45 for the set of three… just be patient & watch.
Very simple to use…
Flush trim/Pattern bits are GREAT too using templates to cut identical pieces… (everyone knows that, right?)
Here is another Super Jig!
The Kehoe spline cutting jig / system
It's basically a spline system that is slightly tapered (1*) to make a Super Strong joint.
Chas. Neil has also reviewed it.
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: ... My Small Gallery:"
showing 1 through 15 of 46 replies
