29 1/2 degree bevel HELP
« back to Joinery forum
Forum topic by MAS520 posted 02-02-2018 10:39 PM 549 views 0 times favorited 12 replies Add to Favorites Watch
View MAS520's profile
MAS520
29 posts in 575 days
02-02-2018 10:39 PM
I need to cut a29 1/2 degree bevel on a 10” x 5/8” board. I have a 12” compound miter saw. bandsaw, table saw, jig saw, and an abundance of frustration. Any help would be greatly appreciated.
-- Mark,Oelwein Iowa Cardinal Fan!
12 replies so far
18662 posts in 1938 days
#1 posted 02-02-2018 10:51 PM
We need some more info on the size of your board and what end or side you need to bevel. An end cut could be done on miter saw or tablesaw with miter gauge. A long side would be best done at the tablesaw with the rip fence, but you want to bevel it before you make it narrow. Meaning bevel the edge of a wide piece and then cut the piece off afterward.
FYI…..I’m a St. Louis Cardinal fan from St. Louis.
View Gene Howe's profile
Gene Howe
10709 posts in 3510 days
#2 posted 02-02-2018 10:56 PM
Bill’s got it…except for that Cardinal thing.
MAS520
#3 posted 02-02-2018 11:52 PM
My board is 10” wide. Need the bevel on that end. But how do I set up my table saw? Board is 5/8ths thick. Born abd raised in St louis
View gwilki's profile
gwilki
214 posts in 1556 days
#4 posted 02-03-2018 12:15 AM
When you say that you need the bevel “on that end”, do you mean that you need to crosscut a 29.5” bevel that is 10” long? Sorry to be so dim, but I think that is what the others are asking too.
If this is what you need, I would use a table saw sled, tilt the blade to give you a 29.5” bevel and cross cut it.
If your compound mitre saw is a slider and it will cut 10”, you could do the same cut with it.
-- Grant Wilkinson, Ottawa ON
View Loren's profile
10477 posts in 3730 days
#5 posted 02-03-2018 12:35 AM
Perhaps you mean 60.5 degrees. This sort of thing?
View Ripper70's profile
Ripper70
1085 posts in 991 days
#6 posted 02-03-2018 02:18 AM
- Loren
I think we have Bingo there!
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View BurlyBob's profile
BurlyBob
5820 posts in 2347 days
#7 posted 02-03-2018 05:14 PM
Mark, I used a jig very much like Loren’s to cut a 22.5 degree bevel for flag cases. It’s one of those jigs you’ll keep forever. It’s super easy to build and cheap.
View Carloz's profile
Carloz
1147 posts in 673 days
#8 posted 02-03-2018 05:26 PM
This is the worst advise I’ve come across here for a long time. Guess what happens when the board slides into the black on the back a very little bit.
A. The blade will raise the board a small bit. Normally this is not a problem but in this particular case the blade has nowhere to go and pushes into the blade more. You do not need to be a genius to predict what happens next.
- Loren
MAS520
#9 posted 02-03-2018 10:12 PM
I fixed my “problem”. Simply a case of bad planning on my part. thanks to everyone for helping. This is one great place.
View Kazooman's profile (online now)
Kazooman
1087 posts in 2034 days
#10 posted 02-03-2018 10:43 PM
This is the worst advise I ve come across here for a long time. Guess what happens when the board slides into the black on the back a very little bit.
- Loren
- Carloz
I am curious what others think about the practice shownin the picture. I, like Carloz, got a sinking feeling in my gut when I first saw it. That is an accident waiting to happen IMHO.
View MrRon's profile (online now)
MrRon
4917 posts in 3325 days
#11 posted 02-04-2018 06:23 PM
- Loren
- Carloz
I am curious what others think about the practice shown in the picture. I, like Carloz, got a sinking feeling in my gut when I first saw it. That is an accident waiting to happen IMHO.
- Kazooman
I agree 100%.
View pintodeluxe's profile
pintodeluxe
5736 posts in 2895 days
#12 posted 02-04-2018 06:31 PM
1. Short board
2. Board not adequately supported
3. No riving knife
4. No push pads
5. Blade tilted toward fence
Disaster waiting to happen in my opinion.
Specifically, as he finishes the cut the support point will change as the waste is cut off. The edge of the board will fall into the large gap and cause bad things to happen.
