Craftsman 113 tilt issue
Forum topic by TimInIndiana posted 02-02-2018 10:16 PM 465 views 0 times favorited 4 replies Add to Favorites Watch
View TimInIndiana's profile
TimInIndiana
119 posts in 376 days
02-02-2018 10:16 PM
Topic tags/keywords: tablesaw
Hi guys, I’m about a week into owning my Craftsman 113.298762 table saw. I noticed that both the blade height and tilt wheels were difficult to turn, so today I’ve been working on cleaning up the worm screws. I cleaned with an old toothbrush and mineral spirits and then gave both screws a wiping of Johnson’s Paste Wax.
While the cleaning and waxing helped a great deal on the height screw, it seemed to only help the tilt in one direction. When I am tilting the blade to the left, it works very smoothly. When I turn the handle the other way to put the blade back to 90, it’s really tough.
Any ideas what’s going on? Would it have to do with the fact that I have the saw upside down while working on it?
View ocean's profile
ocean
138 posts in 1069 days
#1 posted 02-02-2018 11:06 PM
You might check the trunnions at both ends where the sawdust can collect and jam the cradle from tilting. This happens with regularity so you will have to clean on a regular basis. You might also add a piece of plywood on the wall of the where the adjustment screw passes thru. This will stiffen up the side and prevent bowing of the metal which will cause the screw to be hard to turn.
-- Bob, FL Keys
ocean
#2 posted 02-02-2018 11:09 PM
Just reread your post and yes working on it up side down may change things.
-- Bob, FL Keys
View jonal's profile
jonal
7 posts in 525 days
#3 posted 02-02-2018 11:11 PM
Tim, I have a 113 also. Mine is harder to tilt to the left (toward 45). When tilting you are lifting the weight of the motor, When moving back to 90 you have gravity to your advantage. You said your saw was upside down to work on it so I suspect when you return it upright you will find it to be similar to mine.
woodbutcherbynight
5825 posts in 2645 days
#4 posted 02-03-2018 04:53 AM
+1 on the sawdust building up. Had to do this a few times on my Delta. Thanks Bearpaw for pointing me in the right direction years ago!
