Roller guides vs cool blocks?
Forum topic by tigerwoodsman posted 02-02-2018 06:54 PM 650 views 1 time favorited 12 replies Add to Favorites Watch
View tigerwoodsman's profile
tigerwoodsman
16 posts in 1043 days
02-02-2018 06:54 PM
I’m confused, higher end saws tend to come with roller guides while lower end saws come with blocks. But searching around the inter web ppl tend to like cool blocks better than bearings. What he deal?
-- Just because you shot Jesse James doesn't make you Jesse James
12 replies so far
View Woodknack's profile
Woodknack
11777 posts in 2405 days
#1 posted 02-02-2018 07:13 PM
I’ve only used blocks but from what I’ve heard the bearings tend to wear out quickly and become noisy.
View LesB's profile
LesB
1748 posts in 3468 days
#2 posted 02-02-2018 07:19 PM
The guides and blocks are only to make sure the blade is not deflected too much. If it is properly aligned and tensioned there should not be a lot of contact with the side guides. I have had roller bearings on my saw for 8 years with no problem. My previous saw had blocks and they did show some wear (they were not ceramic).
Look at this video on setting up band saws. https://www.youtube.com/watch?v=wGbZqWac0jU
-- Les B, Oregon
View MrRon's profile
MrRon
4794 posts in 3268 days
#3 posted 02-02-2018 07:20 PM
I have roller guides on the upper end, but cool blocks on the lower end. The reason for this is: if you cut very small bits, and if you have roller guides on the lower end, the small bits can get wedged between the guide and the blade. That can cause damage to the guide and the blade. cool blocks won’t trap small bits of wood.
MrUnix
6766 posts in 2224 days
#4 posted 02-02-2018 07:26 PM
Cool blocks are a marketing gimmick IMO. For a good review of the various roller guides and comparison to the standard HSS guides, see this article over at the Woodworkers Gazette:
14-inch bandsaw guides - Tool Review by Jim Mattson
Check out page 2 where he tests the ‘heat’ myth :)
View Gene Howe's profile
Gene Howe
10532 posts in 3453 days
#5 posted 02-02-2018 07:36 PM
My saw is retrofitted with the Carter bearing guides. I like them. Before, I used milled sticks of oil soaked oak as guides. Cheaper and maybe better than steel or ceramic. Certainly easier on smaller blades. I could set then fairly tight against the smaller blades and the blade would cut it’s own groove. Handy for tight curves.
View splintergroup's profile
splintergroup
2075 posts in 1247 days
#6 posted 02-02-2018 08:24 PM
I agree with the assessment that blocks are better for the lower guide unless some method is used to prevent debris from getting between the side bearing and blade.
Overall, I think both bearings and blocks are fine. Bearings really don’t like messy cuts that leave crud on the sides of the blade, blocks actually help keep the blade clean.
View TheFridge's profile
TheFridge
9608 posts in 1511 days
#7 posted 02-03-2018 12:34 AM
I dislike the bearings personally. They stay gummed up and it pushes the bearing out. I like the regular ol steel blocks myself.
View Planeman40's profile
Planeman40
1179 posts in 2786 days
#8 posted 02-03-2018 02:16 AM
I have read that plain old hardwood makes good blocks and hold up well. My old Walker-Turner 14” cast iron “monster” bandsaw uses Oilite blocks that came with the saw when I bought it used way back in 1960. They are still there working just fine. If they ever need changing, I think I will make some blocks out of a very hard wood like Purpleheart, which I have a bunch of.
Gene Howe
#9 posted 02-03-2018 02:41 PM
- Planeman40
Oil soaked oak or maple does a good job.
View HardCorps's profile
HardCorps
9 posts in 1939 days
#10 posted 02-03-2018 06:30 PM
For those of you that use guides made from hardwood, what type of oil do you soak them in?
-- Steve - Ft. Worth
MrRon
#11 posted 02-03-2018 06:53 PM
I have some lignum vitae that I think would work well as guides.
Gene Howe
#12 posted 02-03-2018 08:25 PM
Steve, I just used oil drained from my truck. If it matters, it was 5W30. Any similar would work.
