Blade Cleaning
Forum topic by sIKE posted 179 days ago 406 views 0 times favorited 26 replies Add to Favorites
View sIKE's profile
sIKE
472 posts in 205 days
179 days ago
Topic tags/keywords: resource humor tablesaw blade
Just had the most interesting experience. Whist prepping for my next project, I decided it was time to clean up my Tenyru Gold Metal 40 tooth saw blade. Out came my Boeshield Bit and Blade Cleaner, spray it and wait the 30 seconds. Pull out toothbrush and start to clean, but wait why isn’t the sticky stuff coming off? Ok spray again and wait 2 minutes (twice the prescribed length). Scrub and the stuff is still not coming off. Now I am baffled. I do not want to pull out the stainless steel brush, but I try it very gingerly with no success. More head scratching. 40 teeth two sides, what to do? Rummage in toolbox, Xacto knife? Yep, sit and carefully scrape the gunk off of each tooth. So after working on getting the blade clean and after 45 minutes of work I finally get the job done. Now I head into the house for the evening and relay my woes to the wifey all the while her eyes are just rolling (I told her I’d be right in 50 minutes ago). The life of a woodworker!
I am unsure as why the gunk was so tough this evening. Glue maybe? Anyone see anything like this before?
View GaryK's profile
GaryK
8411 posts in 439 days
179 days ago
Try letting it sit in Simple Green for the night.
View Pretzel's profile
Pretzel
95 posts in 196 days
179 days ago
naptha is what i use to clean glue, pitch, on every blade. Handsaws, planes,etc. Works well
-- Pretzel L8agn
View Russel's profile
Russel
1214 posts in 390 days
179 days ago
I’ll second the Simple Green. It works wonders, though I have to hide it from the wife who keeps wanting to use it in the house (how am I supposed to find it there?).
8577 posts in 273 days
179 days ago
I use spray on oven cleaner and let it sit for 10-15 minutes.
View Pathpounder's profile
Pathpounder
34 posts in 344 days
178 days ago
Ditto on the Simple Green. It has cleaned up my blade every time.
-- http://ragtimewoodwork.blogspot.com/
View Joey's profile
Joey
185 posts in 266 days
178 days ago
Simple green is good, but try this and you can find it at home depot. It’s called Krud Kutter. spray it on, let it sit for a few minutes and usually just wipe it off. the really hard stuff you can use a brass brush on. the brass is softer than steel so it won’t scratch it.
-- Joey, Magee, Ms http://woodnwaresms.com
View FrankA's profile
FrankA
136 posts in 230 days
178 days ago
I have used oven cleaner on mine a few times, but will give the simple green a shot ans it is much better for me and the enviorment. I have never thought to use it for blades. We keep a gallon jug around for everything else.
Thanks for the heads up.
-- Frank Auge---Nichols NY----"My opinion is neither copyrighted nor trademarked, but it is price competitive."
View DaveLikeGolf's profile
DaveLikeGolf
25 posts in 271 days
178 days ago
It’s odd that the Boeshield cleaner wasn’t able to cut it. Was this the first time using it? If not, has it ever been successful in the past?
When I was researching blade cleaners after buying a decent blade I wanted to keep for a long time, I came across so many differing opinions on the safety of using oven cleaner and simple green on your carbide tip blades. The consensus though was that there was too much danger in breaking down the compound that held the carbide tips on. So I erred on the side of caution and bought the blade cleaner from Rockler. It has gotten everything off my blades. But as for the question as to why the boeshield didn’t work, dunno…
-- David, Lakeland, FL - GO BOLTS!!!
View Jim Crockett's profile
Jim Crockett
93 posts in 184 days
178 days ago
What type(s) of wood had you been cutting – anything unusual?
I have found that Lestoil works better than anything else I’ve tried. Acetone would probably work well, but would be a little concerned about the flammable fumes.
But I am surprised that the Boeshield didn’t work well.
JimC
View TomK 's profile
TomK
364 posts in 325 days
178 days ago
Orange oil works too, also biodegradable and you can dilute it afterward and pour it on your fire ant mounds!
-- North Texas
View TampaTom's profile
TampaTom
51 posts in 204 days
178 days ago
Greased lightning takes the pitch and residue off any blade in minutes… works like a champ for me…
-- Tom's Workbench - http://tomsworkbench.com
View juniorjock's profile (online now)
juniorjock
280 posts in 216 days
178 days ago
and don’t forget the krud kutter. works pretty good.
-- Make things with wood.
View sIKE's profile
sIKE
176 days ago
Thanks folks for all of the advice! I have krud Kutter on hand, will try that next rime.
I have been cutting primarily Red Oak, Maple, Maghoney, some pine, lots of Plywood, and I think the culprit, laminations with TiteBond III.
View Tony's profile
Tony
551 posts in 481 days
176 days ago
Oven cleaner – its free from the kitchen, just don’t tell the wife
Any citric acid (orange, lemon, lime) works well and its environmentally friendly. Invest in a copper (they make them for cleaning suede shoes) or bronze brush, its harder than nylon, but not hard enough to damage steel or carbide.
GaryK
176 days ago
Pine will do it too.
View OttawaP's profile
OttawaP
37 posts in 177 days
174 days ago
Ok let me pay this favour forward. Arm and Hammer Washing soda is the fastest and best cleaner out there for saw blades. A box of this will last a lifetime and works better than anything I’ve tried and I’ve tried them all. Add a tablespoon to some warm water and soak your blade in it for 10 minutes or so. A gentle cleanse with an old toothbrush and it’s new again. No effort, no scubbing, no expensive wasteof time, no kidding.
Go for it.
-- Paul
11647 posts in 611 days
173 days ago
sure you grabbed the right container??
just had to say it.
View USCJeff's profile
USCJeff
793 posts in 519 days
173 days ago
Anyone else heard that oven cleaners can deteriorate the glue that bonds the carbide teeth? Maybe a myth, but I’ve seen it written in many places.
-- Jeff, South Carolina
View SPalm's profile
SPalm
702 posts in 333 days
173 days ago
Jeff, I think that is an urban legend. (?) It is nasty stuff though. I have found the new ‘blue can’ oven cleaner for self cleaning ovens to be much nicer stuff to use. You don’t have to wear gloves or anything.
I still like simple green myself to get 90% of it off.
View Al Killian's profile
Al Killian
178 posts in 204 days
173 days ago
The oven cleaner has a chemical in it that “can” soften the brazing that holds the teeth on. I have been told this by a few guys that sharpen blades for a living. Just the idea of it having a chance is more then enough to keep me from using it.
View normand's profile
normand
47 posts in 191 days
167 days ago
I have not tried the Arm and Hammer approach while it may be worth a shot.
I have used oven cleaner , somtimes with the aid of a brass wire brush with good results, and agree with those who have used this method. It may be a little messy but cardboard scrap or paper towels under the blade works.
I do not use gloves but this is a matter of choice.
Norm.
” exceptions to the rule should not become the rule “
View rikkor's profile
rikkor
7198 posts in 325 days
167 days ago
WD-40 cleans a lot of residue.
-- Maplewood, MN
OttawaP
167 days ago
I repeat this thread is no longer valid. Arm and Hammer super washing soda, warm water,wait 10-30 minutes, gentle cleanse…...done. As a matter a fact I should buy 50 pounds of this stuff, portion it off and sell it as blade cleaner at 50 times the price !!! Trust me on this jocks, it’s the best thing going.
-- Paul
View TheCaver's profile
TheCaver
70 posts in 290 days
167 days ago
CMT blade cleaner is the best I’ve ever used…..
JC
-- Somewhere, something incredible is waiting to be known. -Carl Sagan
View brianinpa's profile
brianinpa
530 posts in 174 days
167 days ago
I have had problems like this when cutting plywood. For that reason I have a sepate blade (40 tooth) for only plywood and when I am done, i soak it in naptha for a few minutes, then hit it with a soft brisle tooth brush and it cleans right up.
teenagewoodworker
1950 posts in 219 days
167 days ago
i use simple green. its less expensive (like the router mats they cost like 20 dollars at Rockler and i just use the ones i get at a food store for 5$) and it works great.
Bookmark And Share This Page
