How do I get amazing joints?
« back to Joinery forum
Forum topic by AbbyL posted 02-01-2018 02:27 PM 1012 views 0 times favorited 28 replies Add to Favorites Watch
View AbbyL's profile
AbbyL
12 posts in 234 days
02-01-2018 02:27 PM
Topic tags/keywords: tips cutting boards
I am currently making cutting boards. I’ve made a few before and have never gotten good joints. I cut all my 1” strips on a table saw. They were uneven so I put them through my planer a couple times. When I hold the pieces of wood together I can still see light through. How do I get a good joint before glue up?
28 replies so far
View Logan Windram's profile
Logan Windram
347 posts in 2581 days
#1 posted 02-01-2018 02:41 PM
I would get a razor sharp handplane and hit each side of a glue joint- think about it this way, your planer doesn’t cut flat, it takes thousands of scallops and scoops due to the circular cutting nature of the machine, so your mating surfaces are not getting full glue surface connection. Look down your components lengthwise and you will see the very so slight scallops….
Same technique for table top glue-up, or face mating glue-ups- once you get used to it, do spring joints to improve your strength and gluing accuracy.
Good luck!
View RobHannon's profile
RobHannon
145 posts in 649 days
#2 posted 02-01-2018 02:42 PM
Sounds like either your planner blades needs some adjusting or the opposite side of the boards are not flat causing it to rock as it goes through. If they are large boards and you have a jointer I would try that. Small you can use shims and hot glue to get them level on a flat surface like a scrap piece of mdf and pass them through the planer.
I recently had this happen to me on my planer and a wood chip had gotten under one of the blades making in convex. Still not sure how I pulled that off but was an easy fix.
View Loren's profile
10477 posts in 3767 days
#3 posted 02-01-2018 02:50 PM
It seems likely to me that your pieces are
curving. They may also be coming out of
the planer thinner in the middle.
Glue joints can be refined by running the
parts over a jointer, using a router table
set up for edge jointing, jointing with a hand
plane, or even rubbing the parts back and
forth on a flat surface with sandpaper taped
to it.
Table saw methods like this may also
work.
View jerkylips's profile
jerkylips
446 posts in 2689 days
#4 posted 02-01-2018 02:52 PM
I know I guy. Call me.
AbbyL
#5 posted 02-01-2018 02:58 PM
Loren I’ll try doing the sandpaper and table thing. I’m not experienced enough to know all the wood working terms. But the cheapest route is the best for me so I’ll give that try. What grit sand paper would work best?
View Monte Pittman's profile
Monte Pittman
29795 posts in 2457 days
#6 posted 02-01-2018 03:01 PM
Welcome to Lumberjocks
Where are you located? If you’re close to many people here, I am sure someone would let you use a jointer.
#7 posted 02-01-2018 03:09 PM
- AbbyL
Try to make sure the surface is really flat. I
have a scrap of MDF with a length of 6”
sanding belt glued to it.
I wouldn’t do a whole batch without checking
the joints. If your sanding surface is out of
flat the first few joints will probably tell you.
If you have a stone counter top in the house
those tend to be pretty flat.
AbbyL
#8 posted 02-01-2018 03:10 PM
I am in Houston Texas. My countertops are old and uneven. Ahaha. I’ll test it out a couple times on my fold out table
AbbyL
#9 posted 02-01-2018 03:11 PM
Actually. I have a scrap piece of that stuff too. I’ll use that. Thanks. :)
AbbyL
#10 posted 02-01-2018 03:21 PM
This good right?
#11 posted 02-01-2018 03:26 PM
Yeah, that sort of thing exactly.
You can mark the wood with chalk or pencil
which makes it easy to see where material
is being removed by the sand paper.
AbbyL
#12 posted 02-01-2018 03:31 PM
When I clamp them together with my my hands I am now seeing no light.
jerkylips
#13 posted 02-01-2018 03:39 PM
no one mentioned it, but something may be off on your table saw, too. If the blade is not parallel to the fence, you could be getting cuts that aren’t square. If your blade is dull & you’re having to force the wood through, you could be putting uneven pressure on it/letting it come away from the fence.. That sort of thing..
AbbyL
#14 posted 02-01-2018 03:41 PM
I don’t have my own table saw yet. I was using a family members one and it is very old and makes sounds it shouldn’t. I’ve learned my mistake with theses boards. One I need more practice with a table saw. Really all power tools and two get my own table saw.
View Sludgeguy's profile
Sludgeguy
34 posts in 241 days
#15 posted 02-01-2018 03:44 PM
showing 1 through 15 of 28 replies
