Chamfering End Grain
Forum topic by EdsCustomWoodCrafts posted 02-01-2018 06:23 AM 641 views 0 times favorited 11 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
864 posts in 1544 days
02-01-2018 06:23 AM
Topic tags/keywords: chamfering end grain through mortise and tenon
Hi Guys
I am working on an solid oak end table with through mortise and tenon joinery and I want to add a decorative profile in the through tenon.
I don’t have a hand plane at least in working condition, I do have chisels, tablesaw , router table
Does anyone have a method to chamfering the end grain on the through tenon that will negate any tear out
Thanks
Ed
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
11 replies so far
View jerryminer's profile
jerryminer
944 posts in 1643 days
#1 posted 02-01-2018 06:53 AM
I suppose you could carefully pare some chamfers with a sharp chisel, or run the pieces on a tablesaw sled with the blade at a 45* angle, but really, a small plane is the ideal tool for this job. Time to tune up that not-in-working-condition plane!
View jdh122's profile
jdh122
1052 posts in 3019 days
#2 posted 02-01-2018 11:25 AM
It’s possible with a very sharp chisel. If I had to do it without using a plane I’d probably use a v-groove bit in the router table.
-- Jeremy, in the Acadian forests
View Ron Aylor's profile
Ron Aylor
2649 posts in 849 days
#3 posted 02-01-2018 12:09 PM
Do you have a flat file? I chamfer through tenons with a flat file. The file alleviates tear-out. It takes patience, but it works!
View Carloz's profile
Carloz
1147 posts in 793 days
#4 posted 02-01-2018 01:06 PM
Do you have a sander or at least some sand paper ?
View LittleShaver's profile
LittleShaver
422 posts in 821 days
#5 posted 02-01-2018 01:13 PM
Sandpaper on a block works. With oak I’d start at 80 grit.
-- Sawdust Maker
View bondogaposis's profile
bondogaposis
5091 posts in 2553 days
#6 posted 02-01-2018 01:16 PM
Sand paper and a block would be your best bet. My preferred method would be with a block plane, but sandpaper backed with a block of wood would be my second choice.
-- Bondo Gaposis
View bigblockyeti's profile (online now)
bigblockyeti
5286 posts in 1922 days
#7 posted 02-01-2018 01:21 PM
If you have a tenoning jig for the table saw, that could work well for chamfering the cheeks, especially if you’re creating a large chamfer. Otherwise a sanding block or powered sander with a stiff pad would be your best bet.
View bbasiaga's profile
bbasiaga
1240 posts in 2196 days
#8 posted 02-01-2018 01:44 PM
If you use your chisel, just make sure to start by cutting the back end of the cut. This will avoid speltching. It’s not hard to do with a sharp chisel. If you use a plane it is a good thing to do as well.
To be .more clear, if you are working on the ten on from right to left, come in from the left and pare off a bit of the chamber at the end first, then do the rest right to left. Otherwise it will have the risk of blowing out the left end when you get there. Same is true if planing.
Brian
View rwe2156's profile
rwe2156
3171 posts in 1682 days
#9 posted 02-01-2018 04:56 PM
A ww’er without a hand plane is like, like …...... like a pitcher without a rosin bag….... You’ll never get a grip on your ww’ing without one :-)
Seriously, I’m pretty dexterous, but some of the worst cuts I’ve gotten is chamfering edge grain with a chisel.
Ed—glue a piece of 100 and a piece of 300 grit on a some wood and this works great.
View gargey's profile
gargey
1013 posts in 977 days
#10 posted 02-01-2018 05:04 PM
Great time to buy a little block plane like an LN 60 1/2. If you do wood, you’ll use it for the rest of your life.
View HTown's profile
HTown
114 posts in 1388 days
#11 posted 02-02-2018 07:13 AM
Sharp chisel at a skew working in light passes down to layout lines. If you need, cut a board on a 45 and clamp it to the tenon before you glue it up, then use that as a guide for consistency. Good luck.
