Delta 22-560 Planer
Forum topic by arkahoot posted 02-01-2018 01:42 AM 244 views 0 times favorited 4 replies Add to Favorites Watch
View arkahoot's profile
16 posts in 2012 days
02-01-2018 01:42 AM
I picked up a used Delta 22-560 planer a couple of years ago for $75 and it’s worked pretty well, especially once I replaced the blades and one of the blade hold downs (which had bent as a result of chips getting packed under the blade). Recently, the height adjustment has become difficult to operate. It seems to bind up really bad. I sprayed some penetrating oil on the vertical threaded shafts, which seems to have helped. Not sure if it is something else. Anyone else have this problem?
View Loren's profile
10081 posts in 3578 days
#1 posted 02-01-2018 01:47 AM
Benchtop planers have a chain-drive system
in the bottom. It may benefit from some grease
in the sprockets. The plastic covers on the sides
can be removed as well and the posts lubricasted
with paste wax.
#2 posted 02-01-2018 02:29 AM
Well hot dang! The underside was just packed full of wood chips. No wonder I was having so much trouble!
Thanks Loren!
View pintodeluxe's profile
5587 posts in 2743 days
#3 posted 02-01-2018 02:38 AM
Yeah, my only issue in the past has been chips accumulating. Glad you figured it out.
Side note: Keep the planer bed lubricated with a dry lube like Bostik Glide Cote. I use it on my planer bed, screw posts (and plunge routers too!). It makes all the difference.
#4 posted 02-02-2018 03:43 AM
Thanks PintoDeluxe! Where do you get that dry lube? HD or Lowes?
Nice quote BTW! First concert was Moving Pictures tour in 1981 in ATL!
