SawStop dado set recommendations
Forum topic by AlmostRetired posted 01-31-2018 12:54 AM 2855 views 0 times favorited 24 replies Add to Favorites Watch
View AlmostRetired's profile
AlmostRetired
219 posts in 913 days
01-31-2018 12:54 AM
Being that I am in the search for a dado set I sent an email to SawStop. See below for their response.
On Mon, Jan 29, 2018 at 5:52 PM, Technical Service wrote:
Roger,
•Forrest Dado King DK0824XXX (5/8” arbor)
•DeWalt DW7670 8” Dado Stack
•Freud SD208S 8” Dado Stack (NEW, March 2017)
•Tenryu GMD-20340
•King Canada KSC-8000
•Amana 658040
service@sawstop.com 1 (503) 582-9934
Certain types of blades are not recommended for SawStop saws as outlined
below:
1.Blades with “shoulders” should not be used on any SawStop saw.
2.Wobble dado blades should not be used on any SawStop saw.
3.Full plate dado chippers should not be used on any SawStop saw.
4.Dado blades over 8 1/16 inch diameter should not be used on any SawStop
Jobsite Saw.
Keep in mind that you also do not want to go over 13/16” on the thickness
of a dado set. The 8” dado brake cartridge is not designed to stop dado
stacks thicker than 13/16” and a serious injury may result.
If you have any further questions please give us a call at 503-570-3200. We
also have CASE ID: 75-81026 set up for you to give to the first available
tech. that answers the phone.
Best regards,
SawStop Customer Technical Support
As I am very interested in the Infinity Dadonator I followed up with a specific questions about it.
Good morning,
Thank you for your feedback below. In addition the sets listed below can
you please tell me if the Infinity Dadonator (silly name) is recommended or
not?
Thank you,
Roger
And this was their reply.
Roger,
The “Dadonator” dado set is not recommended to be used with SawStop saws because of it’s weight. If you were to use this set, and have an activation, it has the potential to cause damage to the internal components of your saw. If you have any further questions please give us a call at 503-570-3200. We also have RMA# 75-81026 set up for you to give to the first available tech. that answers the phone.
Best Regards
SawStop
Technical Service
This was bad news as the Dadnoator was in the lead. Looks like I need to save some more cash for the Forrest set.
24 replies so far
View jonah's profile
jonah
1920 posts in 3498 days
#1 posted 01-31-2018 12:56 AM
Look at the Freud SD508 (the Super Dado set). It’s usually under $200. If you only have $100 to spend, the Delta is by far the best buy.
View bbasiaga's profile
bbasiaga
1240 posts in 2194 days
#2 posted 01-31-2018 01:16 AM
I use the Dewalt with my PCS and get great results. I am not sure how much better a set twice the cost would be, but this one is great. Flat with virtually invisible bat ears. Usually less than $150.
Brian
View YesHaveSome's profile
YesHaveSome
128 posts in 458 days
#3 posted 01-31-2018 01:22 AM
Brian
- bbasiaga
I have the Dewalt as well for my CNS. I bought it when I got the saw on recommendation from the Woodcraft salesperson. He said the Freud was the Cadillac but if I didn’t want to spend Cadillac money then the Dewalt was the way to and they just so happened to have the Dewalt in stock!! What a coincidence! I was in a haze from dropping $2300 on a power tool so he probably could have recommended Arizona ocean front property and I would have gladly taken that off his hands as well.
Regardless, I’d say it’s been used a decent amount and done a good job for me.
-- But where does the meat go?
View clin's profile
clin
954 posts in 1195 days
#4 posted 01-31-2018 01:28 AM
Dewalt for my SS PCS as well.
-- Clin
View jmos's profile
jmos
902 posts in 2569 days
#5 posted 01-31-2018 01:12 PM
You could run your saw in bypass while using the dado stack if you don’t want to risk an issue. I’ve had a dadonator for a while, and recently upgraded to a SawStop. I haven’t had occasion to use the dado stack yet, but would probably run in bypass after seeing what the Tech Service folks told you. I certainly don’t plan on replacing the dado stack. I wouldn’t consider a dado cut high risk.
-- John
AlmostRetired
#6 posted 01-31-2018 01:20 PM
I hear you on that one. Only concern I would have is that I want to use the safety, no matter how minor that cut could be. Alos, if I ever had to make a warranty claim when using it I would want to make sure I was in accordance with their direction….regardless of the fact that I want to buy that set…REALLY REALLLY BAD.
For those of you using the DeWalt and Forrest sets…how many times have you had to perform multiple cuts to get the exact size you needed? My big ticket with the Dadonator is their Dado Measuring Gauge…that thing looks AWESOME.
https://www.infinitytools.com/dado-saw-blade-dadonator-6752
You could run your saw in bypass while using the dado stack if you don t want to risk an issue. I ve had a dadonator for a while, and recently upgraded to a SawStop. I haven t had occasion to use the dado stack yet, but would probably run in bypass after seeing what the Tech Service folks told you. I certainly don t plan on replacing the dado stack. I wouldn t consider a dado cut high risk.
- jmos
View Carloz's profile
Carloz
1147 posts in 791 days
#7 posted 01-31-2018 02:04 PM
Dadonator is not recommended for Sawstop.
As for the measuring gauge…. That is intended for suckers with big pockets but small brains.
Take your dado stack and make many slots in a piece of wood, all with different combinations. Write down the chippers and inserts you used for each slot and you have even better gauge.
- jmos
- AlmostRetired
AlmostRetired
#8 posted 01-31-2018 02:11 PM
You are absolutely correct. I was trying to be lazy and you called me on it.
Roger
- jmos
- AlmostRetired
- Carloz
bbasiaga
#9 posted 01-31-2018 02:54 PM
I usually measure the board that will go in the dado with a caliper, then figure out the chipper and shim combo that gets closest. Usually one or two test cuts and I an good to go.
Brian
AlmostRetired
#10 posted 02-07-2018 12:56 PM
So, how does everyone feel about he shims in the DW set? I am leaning towards the Forrest DK as the chippers make the different widths, not the shims.
Roger
bbasiaga
#11 posted 02-07-2018 01:42 PM
The Dewalt set has a umber of 1/8” chippers, and a 3/32. That is used to make all the nominal sizes. The shims are used to tweak to get an exact fit. Your board come off the planer at .76 instead of .75? Stack up your chippers for .75 and add a .01 shim.
Slightly undersize piece of ply? Replace one of the 1/8” with the 3/32” and add shims as necessary to match the thickness. It isn’t hard. The only trick is to set the shims so they don’t get caught in the threads of the arbor.
I am not sure how many different chipper widths you would need to replicate that without having to use shims at all.
Brian
View BroncoBrian's profile
BroncoBrian
847 posts in 2158 days
#12 posted 05-19-2018 09:04 PM
Fellas, I don’t mean to bring up something too old.
No one mentioned the Freud Super Dado in this thread (or I cannot read). At $200 that is what Woodcraft recommended to me. I am thinking if Brian says the Dewalt is good and I have to buy a cartridge and insert as well, that might be more than sufficient for my PCS.
The $75 saved on the dado nearly buys the cartridge.
-- A severed foot is the ultimate stocking stuffer.
View PropmakerLA's profile
PropmakerLA
12 posts in 209 days
#13 posted 05-20-2018 10:40 PM
I have the Freud Dial a Dado and really like it. I find it a lot easier to just loosen the nut and make adjustments rather than removing the nut and changing shims.
View TrentDavis's profile
TrentDavis
41 posts in 2435 days
#14 posted 05-21-2018 11:50 PM
Check out the following article. It is focused specifically on dado considerations with a SawStop.
http://trentdavis.net/wp/2016/08/31/dado-information/
-Trent from SawStop
-- SawStop Users' Group: https://www.facebook.com/groups/sawstopusersgroup/
View Blindhog's profile
Blindhog
94 posts in 1248 days
#15 posted 05-22-2018 01:01 AM
I use the Forrest DadoKing with Freud steel shims to get the exact fit. As stated previously, get the fit you want using the shims for the sheet goods you use and then standard cutter combos for the rest. Make passes in a legend board and you’re good to go.
-- Don't let perfection get in the way of plenty good enough
