what to do with porous oak
Forum topic by skidiot posted 01-30-2018 05:02 AM 545 views 0 times favorited 8 replies Add to Favorites Watch
View skidiot's profile
skidiot
73 posts in 3672 days
01-30-2018 05:02 AM
Hi,
I recently quarter sawed some red oak boards. The figuring is spectacular, but the pores are so big and deep I am afraid that they will obscure the figuring. Should I use a grain filler? I plan on using a water based stain (General Finishes medium brown). I dont know very much about difficult finishing. All I do is wipe on a stain when dry 3 coats of poly.
Thanks
Skidiot
-- skidiot northern illinois
8 replies so far
View jerryminer's profile
jerryminer
928 posts in 1469 days
#1 posted 01-30-2018 05:26 AM
Oak is one of those open-pore woods that grain filler was created for. You don’t need to fill unless you want a completely smooth surface. Some people like the open-pore texture. It’s a matter of personal preference. If you do fill, you can choose a filler that “blends” with the background color, or a filler that provides a contrast.
You really should do a couple of samples on some scrap material and figure out what your preference is.
skidiot
#2 posted 01-30-2018 05:31 AM
Hi,
Am I correct in thinking that the stain will fill the pores and get real dark. The dark pores will obscure the figuring of the quarter sawn oak. If I fill in the pores so they dont fill with stain, will this help accentuate the figuring?
Skidiot
View Woodknack's profile
Woodknack
11813 posts in 2407 days
#3 posted 01-30-2018 05:34 AM
Depends on if the wood filler will accept a stain, many don’t, even if they say they do. Definitely test on scrap. Some people like the pores darker than the surrounding wood, up to you though.
View TheFridge's profile
TheFridge
9608 posts in 1513 days
#4 posted 01-30-2018 05:48 AM
Burn it and buy some alder.
View CaptainKlutz's profile
CaptainKlutz
284 posts in 1522 days
#5 posted 01-30-2018 07:21 AM
+1 = if you don’t need a flat surface, then ignore pores. Most might need is to add an extra coat of poly if you leave them unfilled.
As long as you are coloring wood and you want flat surface, suggest filling oak grain with Behlens water based grain filler. [Brush some on, rub it into grain, scrape across grain to remove excess, sand when dry.] Filler drys a neutral off white color and absorbs stain/dye evenly, but without making the pores too dark? Have tried using regular colored grain fillers like Timbermate, and unless I need contrasting color in pores, always end up using Behlens water base filler to create flat surfaces for dyed/stained parts.
IMHO – If you have good figure on QSRO, then would suggest using Behlens or Mowhawk brand dye stains (or make your own dye stain with Transtint, etc), and not using GF water based stains. GF stains are nice, but are heavy bodied, and will obscure figure more than dye stain.
I used the above water based filler, dye stain, poly process on both of my Oak projects posted (and on Walnut too) if you want to see results I get, but as always YMMV.
View Dave Polaschek's profile
Dave Polaschek
2214 posts in 609 days
#6 posted 01-30-2018 11:11 AM
I’ve got a bunch of oak around the house. Some of it has the pores left open, some has the pores filled. I’ve had years to live with it, and the oak that had open pores and was poorly finished gets its pores filled by dirt over time. With filled pores, you can control the color, but I like the look of dark-filled pores in lighter red or white oak.
The other thing I’m experimenting with for Valentine’s Day is filling the pores of red oak with dyed filler. I’m experimenting with red TransTint added to white WunderFill from Rockler. It’s looking interesting in a good way so far. I’ll post a picture when it’s done, but I would encourage you to take a few offcuts or scraps and experiment. White filler vs black filler vs natural oak vs none, then finish with stain and poly or shellac over the top and see which you like when it’s all done. Try some without stain too.
It’s quite a rabbit hole to venture down, but I’m enjoying it. Even just walking around my house and trying to figure out what was done for the finish on the various bits of oak furniture I have was informative.
-- Dave - Minneapolis
View runswithscissors's profile (online now)
runswithscissors
2767 posts in 2052 days
#7 posted 01-31-2018 01:21 AM
You might consider using a Danish rubbed oil, such as Daly’s Ben Matte. It’s very easy to use. You wet the wood with the oil, then immediately sand with fine wet-or-dry paper, 400 to 600 grit. The fine particles of wood form a slurry, which is forced into the pores. You then wipe the excess off with a rag. Only the first coat needs to be wet sanded. Building up with subsequent coats will give you a shinier finish, though I don’t think you can get a true high gloss out of it.
It also comes in various stain colors, but maybe not necessary for walnut.
View LesB's profile
LesB
1748 posts in 3470 days
#8 posted 01-31-2018 06:48 PM
Red oak is very open grain wood so is mahogany. If you need a close grain figure try white oak, maple, birch, beech or similar woods.
I have used a lot of red oak and the only time I fill the grain is on top surfaces like counter tops, table tops or shelves so they are completely smooth. An extra couple of finish coat layers can accomplish the same thing most of the time. Yes the open grain does pick up more stain (especially dark stains) but that is part of the oak character and it accentuates the grain of the wood. A wood sealer (not a filler) will help control the stain some and allow you to wipe out more of the stain that gets into the pores if that is what you desire. Do some test pieces to see if you like it….this a process I always do before I stain any of my work.
In applying the wood filler follow the instructions carefully or you could end up doing a lot of sanding to remove the excess filler that drys on the surface….don’t ask how I know (-:
-- Les B, Oregon
