Table Saw - Router Table extension mounting
Forum topic by vernonator posted 03-31-2011 07:06 PM 1324 views 0 times favorited 1 reply Add to Favorites Watch
View vernonator's profile
vernonator
75 posts in 2558 days
03-31-2011 07:06 PM
Topic tags/keywords: question router tablesaw
Newbie here – I recently purchased a General 50-240 table saw. I have a small shop and am planning on mouting an extention router table on the right side using the saws fence supports (these extend 18” or so past the end of the right leaf). My concern is how do I line up the top to be level with the saw? There ARE holes in the fence that I can use, but I am worried about drilling accuratly enough to get the table mounted flush and level.
Any advice will be GREATLY appreciated.
Thanks
Mark
1 reply so far
View Alan S's profile
Alan S
180 posts in 3224 days
#1 posted 03-31-2011 08:56 PM
The best advice I have seen about this kind of task is to temporarily clamp the extension in place with several boards extending from the main table saw top over to the new extension wing. Clamping on both the original table saw top and the new extension wing top will insure that the wing is positioned level with the original top, then you can secure it from the sides with screws through the fence rail brackets. Drilling the holes in the extension wing slightly over-sized will allow some slop to play with.
Alan
