Question on Box Lid
Forum topic by Quailguy posted 01-28-2018 06:54 PM 267 views 0 times favorited 2 replies Add to Favorites Watch
View Quailguy's profile
Quailguy
60 posts in 1311 days
01-28-2018 06:54 PM
I am building a small, curly maple box and would like to incorporate a flat, flush fit top with a lift tab/lift that sits in a notch at the front of the box. I have seen these tabs made from a separate piece of wood, but would like to make the tab and lid from one piece. How can I cut the straight lines on either side of the tab? Should I rip the front lid edge straight and make the tab from the cut-off portion? I would like to eliminate glue lines where they connect. I apologize if I haven’t painted an accurate picture of what I’m looking for.
Quailguy
2 replies so far
View Aj2's profile
Aj2
1662 posts in 1918 days
#1 posted 01-28-2018 07:03 PM
I think I know what your asking. Because I’ve made boxes with type of lid the answer is bandsaw.With a fine tooth blade so there is less clean up work.
Good day sir
-- Aj
Quailguy
#2 posted 01-28-2018 07:09 PM
That makes sense. Thank you very much!
