Flattening Water Stones.
« back to Hand Tools forum
Forum topic by Don posted 01-28-2018 03:28 AM 732 views 0 times favorited 11 replies Add to Favorites Watch
View Don's profile
Don
5 posts in 1179 days
01-28-2018 03:28 AM
I have a few water stones that need to be flattened. Can you suggest what I need to use?
-- Don in Murfreesboro, TN.
11 replies so far
View Andre's profile
Andre
2007 posts in 1921 days
#1 posted 01-28-2018 04:31 AM
I use the Lee Valley DMT DiaFlat™ Lapping Plate, price has gone up since I got mine but it is a 1 time investment!
Or you can get the Truing Stone for Water Stones, much cheaper and will do what you need it to do!
View msinc's profile
msinc
497 posts in 619 days
#2 posted 01-28-2018 05:26 AM
Depending on how bad the stone is I have done it two ways…if it’s not real bad, say .010” – .020” or so you can just use another stone {aluminum oxide}. It does not have to be a special “flattening” stone. Even an old razor hone {ebay} works very nice, especially to finish it. I have also used the Buck knives brand stone to put the final dress on water stones and it works fine. It also works well to keep it flat if used periodically. You should really be giving it a little dress up every time you use it to keep it good and flat.
If a stone is really bad and has a lot of wear, like more than .020” and up I put a finer belt {120 or finer} on my 6X48 belt sander and give it a kiss. i do this dry on the sander and it is easier if you lay the belt down so it’s horizontal and use a scrubbing motion back and forth across the belt while it’s running. Do not put a lot of pressure and go slow, it will get flat. Then take the razor hone to it with water and finish it. I have brought back several water stones from the dead this way and it is quick. This will no doubt make some hone “experts” cry like a fat baby, but I look at it this way…a worn out, dished out stone is no good like it is, so if you mess it up {pretty hard to do really} where’s the loss?
View TheFridge's profile
TheFridge
10090 posts in 1601 days
#3 posted 01-28-2018 07:26 AM
I use an atoma 400g plate. Or any coarse diamond plate would work. I’d hesitate to use any kind of mechanical sander myself.
View Don's profile
Don
#4 posted 01-28-2018 02:32 PM
Thanks for the info. I bought one of the cheaper ones because I don’t sharpen that often. I have two planes a #5 and a block plane 60 & 1/2 plus some chisels.
Andre
#5 posted 01-28-2018 07:12 PM
A quick check for flatness, make a checker pattern on the stone with a pencil, a few rubs will show low spots.
Quick and easy, wrap a 2”x4”(flat) with some 100 – 120 grit sandpaper?
View JayT's profile
JayT
5807 posts in 2326 days
#6 posted 01-28-2018 07:37 PM
I use 220 wet dry paper on a granite surface. Once the stone is flat, the paper can easily be rinsed off.
View PeteStaehling's profile
PeteStaehling
66 posts in 1235 days
#7 posted 01-28-2018 09:47 PM
I use a flattening stone that I bought with my water stones to flatten them, but I have put an old Arkansas Stone that was DEEPLY dished on the belt sander and flattened it right up,
View Vindex's profile
Vindex
93 posts in 937 days
#8 posted 01-29-2018 05:54 PM
I use the DMT 11.5” continuous diamond stone (http://amzn.com/B000PVZDNI). It is the first stone I use when flattening my tools for their first sharpening, and it flattens all of the other stones as well. It’s expensive, but well worth it in my opinion.
View Loren's profile
10477 posts in 3763 days
#9 posted 01-29-2018 06:19 PM
I use a drywall sanding screen. Actually it’s
a floor sanding screen but it’s the same
stuff. One that’s too worn to sand floors
will still flatten a water stone.
Somebody suggested a cinder block. That
sounds barbaric but using the stone for
sharpening will soon remove marks from
coarse abrasives used in flattening.
The best suggestion I have for waterstones
is either use a figure-8 pattern to spread
wear on the stone when honing freehand
or use a sharpening jig which does not ride
on the surface of the stone.
View Just_Iain's profile
Just_Iain
291 posts in 532 days
#10 posted 02-05-2018 03:39 PM
Loren,
What grit of sanding screen do you use? The options I have are 100 to 220 up here in the Canadian HomeDepot.
-- For those about to die, remember your bicycle helmet!
#11 posted 02-05-2018 03:43 PM
I would try 150.
