How do you cut down on dust from a panel saw?
Forum topic by jack1 posted 03-31-2011 05:55 AM 4831 views 0 times favorited 9 replies Add to Favorites Watch
View jack1's profile
jack1
2099 posts in 3932 days
03-31-2011 05:55 AM
Topic tags/keywords: tip panel saw humor
First of all, I love my panel saw. It’s a Milwaukee.
What I don’t love is all the dust it makes and the hassle of cleaning up after making a bunch of cuts. I kept running into pictures of an item called the “big gulp”
I finally decided to get one. Since I didn’t want to hook it up to my big vac, I ordered a step down for my shop vac which of course didn’t fit… I did find some schedule 40 4” id plastic pipe so that I was able to connect the two parts using the handyman’s secret weapon (duct tape), and a few screws. I then used self taping screws to fasten it to the back of the panel saw into the sheet metal.
I hooked up the shop vac, connected it to a slave switch with the panel saw, turned it on a made a few cuts and bingo.
I won’t say there was no dust when I was done but there wasn’t a heck of a lot on the ground or in the air. Works good!
9 replies so far
View donjoe's profile
donjoe
1360 posts in 2935 days
#1 posted 03-31-2011 06:00 AM
Nice Jack, better in the vac than in your lungs or all over the shop.
-- Donnie-- listen to the wood.
View Joe Lyddon's profile
Joe Lyddon
10035 posts in 3957 days
#2 posted 03-31-2011 06:21 AM
Looks good, Jack!
Doesn’t look like a very difficult solution to the problem! COOL!
Nice Panel saw!
View bubinga's profile
bubinga
861 posts in 2572 days
#3 posted 03-31-2011 06:51 AM
I built ,basically ,a copy of the safety speed ,C4 from square steel tubing.
I put a Porter Cable saw ,with dust port,on carriage.
When I cut some MDF ,wow,that was some nasty crap
That was nowhere near enough collection,so I put a trough on back like you did,with,4 in hose
That’s better,BUT, I haven’t done it yet ,BUT,one more thing I plane to do,Is ,something I saw on some commercial models
A rubber like ,clear ,or brush type skirt around the bottom of carriage to keep it from flinging dust out before vacuum can catch it
-- E J ------- Always Keep a Firm Grip on Your Tool
View auggy53's profile
auggy53
159 posts in 2584 days
#4 posted 03-31-2011 06:52 AM
nice set up , wish i had one sometimes . f.y.i. i needed a fitting for my vac. a while back so i used a short piece of p.v.c. and turned down both ends of the pipe on my disc sander to fit the vac. , i didnt want to put it on the lathe , it fits!
-- rick
Beginningwoodworker
13347 posts in 3577 days
#5 posted 03-31-2011 02:56 PM
Jack that looks better.
View Jonathan's profile
Jonathan
2608 posts in 2955 days
#6 posted 03-31-2011 04:01 PM
Great solution, Jack!
I’d say that was worth the $30 (or so) in parts.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
View BTKS's profile
BTKS
1986 posts in 3369 days
#7 posted 04-01-2011 06:36 AM
You lucky guy, a panel saw! I would be happy with our without the dust! Funny, the simple solutions are usually the best and you got a good one here! Thanks for the idea, I think I can apply something similar to my compound miter saw.
BTKS
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
View Viking's profile
Viking
880 posts in 3099 days
#8 posted 04-01-2011 09:33 AM
Jack;
Most LJ’s would love to have a real panel saw, many have done research on them. It would be great if you could do a real review on your Milwaukee now that you have used it a while.
Thanks for sharing you DC idea.
Good luck!
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
jack1
#9 posted 04-01-2011 07:42 PM
THanks guys. I actually have only about $20 in parts even if you consider the screws… Amazon has pretty good deals on vacuum fittings.
I might write up something on the panel saw. I will say it beats bribing friends to help you load 3/4” oak 4×8 sheets onto your table saw! The saw is advertised as being within 1/32” cutting accuracy and I can vouch for the number and even closer to perfect if you are careful. I did add a finer blade to it (see a previous posting) and get almost no chip out even without using tape…
